Help with ADC1015 gain values
by busterbot on Sat Jun 20, 2020 12:09 pm
Hi, I tried following the example for the ADC1015 i2c ADC breakout board but I'm a little lost with the gain setting.
https://learn.adafruit.com/adafruit-4-channel-adc-breakouts/python-circuitpython Bottom of the page.
The article says changing the gain will not change the output voltage calculation, but that's not what I am seeing when I follow the example, not sure what I'm doing wrong. I'm using a Raspberry Pi Zero and have input 1 tied to Vdd which is powered from the 3.3v pin on the Pi.
import board
import busio
import adafruit_ads1x15.ads1015 as ADS
from adafruit_ads1x15.analog_in import AnalogIn
i2c = busio.I2C(board.SCL, board.SDA)
ads = ADS.ADS1015(i2c)
ads.gain = 1
chan = AnalogIn(ads, ADS.P1)
print(chan.value, chan.voltage)
ads.gain = 16
When I run this I get this output:
26496 3.3121010773033848
32752 0.2558828089236122
I was expecting the second at gain 16 to still show around the 3.3 level like it does in the example.
busterbot
Re: Help with ADC1015 gain values
by adafruit_support_carter on Mon Jun 22, 2020 2:05 pm
The gain setting also affects the full scale range for the ADC. See table 3 in the datasheet:
https://cdn-shop.adafruit.com/datasheets/ads1015.pdf
So at 16x, the max is ~0.256V, which is what you are seeing the serial prints.
