how to precompile a .py file to a .mpy file Windows 10
by Assemble_In_Mexico on Thu Jun 25, 2020 12:25 pm
Using Windows 10.
I've developed a nifty new project, installed Python and the mpy-cross module, slain dragons and successfully battled with memory issues yet I cannot compile a .py to an .mpy file. Could someone so kindly post some tips?
- The project usage section (https://pypi.org/project/mpy-cross) doesn't work for me such as within a command prompt using
python -m mpy_cross filename.py
- The github project (MicroPython cross compiler) talks only about a Unix system.
- CircuitPython releases (https://forums.adafruit.com/viewtopic.php?f=60&t=145860) state that pre-built mpy-cross executables are available above for MacOS, Windows, Ubuntu, and Raspbian, yet I don't see anything useable.
I'm embarresed I can't see how to do this simple task and only hope that learning how here may be of help to others. Thanks in advance.
Assemble_In_Mexico
Re: how to precompile a .py file to a .mpy file Windows 10
by mikeysklar on Thu Jun 25, 2020 1:06 pm
You will need to install a Windows subsystem for Linux (WSL) so that you can build mpy-cross on your Win10 box.
https://learn.adafruit.com/building-cir ... -for-linux
Once you have the WSL up and running Ubuntu you can build the mpy-cross compiler included with the github repo:
https://learn.adafruit.com/building-cir ... cuitpython
mikeysklar
by Assemble_In_Mexico on Fri Jun 26, 2020 1:59 pm
Wonderful. I was missing the big picture, that of using WSL. Thank you so much for the tip mikeysklar!
Working from the posted instructions I have installed Ubuntu through WSL, cloned CircuitPython, installed and updated all submodules, then built mpy-cross. I should be there yet I am still missing something not specified anywhere in the Adafruit learning section, that of how to make the .mpy file. I see some instruction here if it's helpful --> https://learn.adafruit.com/creating-and-sharing-a-circuitpython-library/creating-a-library#mpy-2982472-11
Suppose I have a single .py file named library.py located in the /circuitpython/mpy-cross directory. With an Ubuntu command prompt how would one make the .mpy file?
Assemble_In_Mexico
by Assemble_In_Mexico on Tue Jun 30, 2020 1:51 pm
Anybody know what Ubuntu command(s) to issue to create a .mpy file?
Assemble_In_Mexico
by mikeysklar on Tue Jun 30, 2020 1:58 pm
Once you have a working mpy-cross compile installed the command to convert your .py to an .mpy is:
mpy-cross example.py
https://learn.adafruit.com/creating-and ... spberry-pi
mikeysklar
by Assemble_In_Mexico on Tue Jun 30, 2020 2:21 pm
Thanks again for the tip compadre. I feel I’m close yet must be missing something stupidly simple.
If I go to the /circuitpython directory and issue 'make -C mpy-cross' it succeeds with
text    data     bss     dec     hex filename
216113   20832     976  237921   3a161 mpy-cross
I then show I have a file say, library.py in the mpy-cross directory, and therein issue mpy-cross library.py yet I am getting an mpy-cross: command not found error.
Assemble_In_Mexico
by jerryn on Tue Jun 30, 2020 2:25 pm
if this is Ubuntu and the mpy-cross is in the working subdirectory, try
./mpy-cross filename.py
otherwise provide the full path the mpy-cross:
/path/to/mpy-cross filename.py
jerryn
by Assemble_In_Mexico on Tue Jun 30, 2020 2:38 pm
Still no dice. My mpy-cross directory is that provided within circuitpython, so I issue
/home/<username>/circuitpython/mpy-cross library.py
and get -bash: /home/<username>/circuitpython/mpy-cross: Is a directory
Assemble_In_Mexico
by mikeysklar on Tue Jun 30, 2020 3:00 pm
You have to compile and install mpy-cross.
 git clone https://github.com/adafruit/circuitpython.git
cd circuitpython/mpy-cross
make
./mpy-cross example/adafruit_example.py
details here:
https://learn.adafruit.com/creating-and ... y?view=all
mikeysklar
by Assemble_In_Mexico on Tue Jun 30, 2020 3:22 pm
Success! I am in your debt mikeysklar. I had everything installed right, it was a matter of being in the right directory and issuing the command for the right directory. All good here; let's hope this may be of help to another poor wanderer as it has been for me.
Assemble_In_Mexico
by mikeysklar on Tue Jun 30, 2020 4:29 pm
well done, Sir!
mikeysklar
cron
