MicroSD not pre-loaded + BME280 not detected
by smcclure11 on Fri Jun 26, 2020 10:53 am
I ordered (#2306274) kit 3592 and pi 3 B 3055. The SD appears to be empty. Only the red led on the pi lights up. When I look at the SD from a PC it reports empty.
How can get this SD loaded with your image or replaced?
Also, I used another SD card that I previously loaded for another pi to try and test the BME280. I installed the drivers and the sample code is reporting no hardware detected. Ideas on this?
Thanks,
Steve
smcclure11
Re: MicroSD not pre-loaded + BME280 not detected
by smcclure11 on Sat Jun 27, 2020 9:27 pm
File "/home/pi/datalogging/sensor_sample.py", line 4, in <module>
i2c = busio.I2C(board.SCL, board.SDA)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 28, in __init__
self.init(scl, sda, frequency)
File "/usr/local/lib/python3.7/dist-packages/busio.py", line 69, in init
(scl, sda), i2cPorts
ValueError: No Hardware I2C on (scl,sda)=(3, 2)
Valid I2C ports: ((3, 3, 2), (1, 3, 2), (0, 1, 0))
smcclure11
by adafruit_support_carter on Tue Jun 30, 2020 7:39 pm
I'll ask about the SD card. But it's also pretty easy to just download an OS image and install it to the SD card from here:
https://www.raspberrypi.org/downloads/
For the I2C issue, make sure you've enabled I2C on the Pi. You can do that via raspi-config.
by adafruit2 on Fri Jul 03, 2020 11:58 am
the microSD should have had NooBs on it, but NooBs updates really often so you're best off following raspi's tutorial to load up the latest version anyhow!
adafruit2
Site Admin
by smcclure11 on Mon Jul 06, 2020 5:09 pm
I did not know if the BME280 problem was related to me not getting the right things installed without the pre0loaded version. But it turns out that not having "enabled I2C on the Pi"
was the problem.
smcclure11
