NeoPixel turns orange when I want it to turn off
by keithsoares on Sat Jun 27, 2020 4:18 pm
I'm a complete rookie, so this is probably a complete rookie mistake, but here goes...
I have a single NeoPixel (not a strip of multiple lights, just one light) wired like this to a Flora:
Flora VBATT => NeoPixel +
Flora GND => NeoPixel -
Flora #6 => NeoPixel DIn
I then have a simple sketch that sets a random number between 2000 and 8000 to represent between 2 seconds and 8 seconds of time. I use this for my delay(). Initially, I set the NeoPixel to a bright green:
strip1.setPixelColor(0, strip1.Color(0, 254, 0));
then, after the delay, I am trying to turn the NeoPixel off with this command:
strip1.clear();
(I have also tried this command: strip1.setPixelColor(0, strip1.Color(0, 0, 0)); )
The problem is that the NeoPixel never turns off. It successfully changes but does not go dark. Instead, it turns a sort of orange color, slightly dimmer than the bright green.
So, my code successfully sets a random delay and successfully changes the NeoPixel, but instead of turning off, it turns orange. Any help on this would be appreciated.
For the record, I am trying to do this with two NeoPixels and turn a servo at the same time, but I have eliminated all of that and reduced the code and wired connections to ONLY the single NeoPixel, and I still get orange instead of off.
K.
keithsoares
Re: NeoPixel turns orange when I want it to turn off
by dastels on Sat Jun 27, 2020 5:07 pm
Can you post the entire sketch, please. And also a clear photo of your wiring.
dastels
by keithsoares on Mon Jun 29, 2020 12:25 pm
Here's the sketch and three photos. The photos show a single NeoPixel and a small servo attached to a Flora. The code works to turn the servo, and the NeoPixel changes at the same time, but it turns orange instead of turning off.
#include <known_16bit_timers.h>
#include <Adafruit_TiCoServo.h>
#define SERVO_PIN 10
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(1,6,NEO_GRB+NEO_KHZ800);
long randNumber;
Adafruit_TiCoServo servo;
int pos = 0;
  // put your setup code here, to run once:
  servo.attach(SERVO_PIN);
  strip1.begin();
  strip1.show();
  // put your main code here, to run repeatedly:
  strip1.show();
  randNumber = random(2000, 8000);
  delay(randNumber);
  for (pos = 0; pos <= 180; pos += 1) {
    servo.write(pos);
  strip1.clear();
  strip1.show();
  delay(2000);
  for (pos = 180; pos >= 0; pos -= 1) {
    servo.write(pos);
Image with NeoPixel on: https://www.dropbox.com/s/kcgu3f7bhib4v ... 0.jpg?dl=0
Image with NeoPixel "off" but turns orange instead: https://www.dropbox.com/s/xlvb8ueochb0t ... 2.jpg?dl=0
Closeup image of Flora wiring: https://www.dropbox.com/s/crth8qw0nf2tb ... 0.jpg?dl=0
keithsoares
by dastels on Mon Jun 29, 2020 1:51 pm
I'm always skeptical of alligator clips, especially on something so sensitive to data corruption as NeoPixels. But you say it always goes to that orange color when it's turned "off"?
dastels
by adafruit_support_bill on Mon Jun 29, 2020 2:00 pm
Another possible variable: Is it an RGB or an RGBW pixel?
by dastels on Mon Jun 29, 2020 2:05 pm
I was wondering about that, Bill, but the green seems fine... and clearing it should write all 0s which shouldn't be impacted. Though I'm not sure how the pixel's shifter works. Hmm.. does the Flora Pixel even come in an RGBW version?
dastels
by keithsoares on Mon Jun 29, 2020 2:35 pm
This is the NeoPixel. I believe it is just RGB and not RGBW.
https://www.adafruit.com/product/1260
keithsoares
by keithsoares on Mon Jun 29, 2020 2:38 pm
My end goal is to use conductive thread to sew this whole thing into a mask for cosplay for my daughter, but I am using the alligator clips now to try to get everything correct before I commit to sewing. The idea is that the two NeoPixels are light-up eyes, and the servo will control blinking eyelids. When the servo fires the blink movement, the lights go off in the eyes.
keithsoares
by adafruit_support_bill on Mon Jun 29, 2020 2:47 pm
Not sure what happens if you send only 3 bytes to an RGBW. But it looks like the Flora's only come in RGB.
What happens if you send it a different color instead of turning it off?
by keithsoares on Mon Jun 29, 2020 3:42 pm
I just ran a few tests.
If I do strip1.setPixelColor(0, strip1.Color(254, 0, 0)); the light turns red.
If I do strip1.setPixelColor(0, strip1.Color(0, 0, 254)); the light turns blue.
But if I try something like strip1.setPixelColor(0, strip1.Color(1, 1, 1)); the just turns orange and does not dim very much. (It looks identical to the photo I posted previously.)
keithsoares
by adafruit_support_bill on Mon Jun 29, 2020 4:18 pm
That's pretty weird. Unless Dave has any other ideas I'd say a replacement is in order.
by dastels on Mon Jun 29, 2020 5:18 pm
Nothing here. That's bizarre.
What product did you buy? The Flora Neopixels come is sets of 4 or 20. Or was it just a single in a project kit of some sort?
dastels
by keithsoares on Mon Jun 29, 2020 5:20 pm
It was exactly this. Four pack. https://www.adafruit.com/product/1260
keithsoares
by dastels on Mon Jun 29, 2020 5:23 pm
Do all 4 behave this way?
dastels
by keithsoares on Mon Jun 29, 2020 5:31 pm
Wow. SOLVED.
It is a faulty NeoPixel.
I swapped it to another NeoPixel and it works perfectly. Sorry to bother everyone...
K.
keithsoares
