Unable to upload to metro mini
I as well am unable to upload blink example to newly received metro mini ATmega328.
Followed instructions at
https://learn.adafruit.com/adafruit-metro-mini, loaded "Adafruit Windows Driver package. When you run it, make sure to click that you want to install the SiLabs CP210x and FTDI chip drivers too!" from instruction set.
A device appears as COM3 when plugged in and disappears when disconnected, PWR on LED is lit, TX LED blinks 3X no RX LED indication.
Computer is MS Surface, WIN 10
Thanks for any help.
Paul
error message
Arduino: 1.8.12 (Windows 10), Board: "Adafruit Metro"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xda
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.>
