panel mount micro sd x micro sd extension
by lpollock on Thu Jul 09, 2020 3:25 pm
Is there any product available like the 3688 micro sd x micro sd extension that would be "panel mountable"?
We manufacture custom rack mount electronic test equipment controllers that use micro sd on the internal controller pcb. We currently use the 3688 micro sd extension cable to enable easy access to the micro sd card. The drawback is this is not mountable and we have to pass it to the outside of the chassis where it just dangles freely. Ideally we would like to be able to manufacture our chassis with a panel mountable micro-sd extension.
sample-photos
lpollock
Re: panel mount micro sd x micro sd extension
by mikeysklar on Thu Jul 09, 2020 3:49 pm
Hi lpollock,
I can see why you would want to mount this more securely.
We do not currently sell a panel mount SD Card Extender.
My guess would be to use an L-bracket and crazy glue to hold the SD extension in place internally. Maybe even add this sort of extension to make it easier to interact with from the outside.
https://www.adafruit.com/product/4395
If you wanted to run your own Micro-SD wiring you could always mount our breakout board securely as it is a real PCB with mounting holes.
https://www.adafruit.com/product/254
mikeysklar
