Resister to Jumper Cable
by Dekaner on Fri Jul 10, 2020 9:04 pm
Need a little help as I'm unfamiliar with the product options. I need to connect a resistor to two pins on a board with a 2x6 male short header. Will I be able to push the resister through this housing pack or should I pick up jumper wires and solder directly to that? Thanks in advance!
Through-Hole Resistors - 100 ohm 5% 1/4W - Pack of 25
--- 220 ohm 5% 1/4W - Pack of 25 ---
PID: 4293
https://www.adafruit.com/product/4293
Small Dual Row Wire Housing Pack for DIY Jumper Cables
PID: 3143
https://www.adafruit.com/product/3143
Dekaner
Re: Resister to Jumper Cable
by dastels on Fri Jul 10, 2020 9:59 pm
I can't quite picture what you're wanting to do. Your goal is to connect each end of the resistor to pins? Can you show a photo of the board you want to connect to.
dastels
by Dekaner on Fri Jul 10, 2020 10:26 pm
Thanks for the quick response. I need to jump pins 1-6 here with a 100 ohm resistor. I'm trying to find a way to do it without soldering directly to the header. Image of the board attached.
Dekaner
by dastels on Fri Jul 10, 2020 10:34 pm
Thanks. It's clear now. So, no, you can't just push the resistor through the holes in the housing and get a reliable connection. I would the jumper wires (female ends) that go with those housings, cut 2, leaving a bit of wire to solder the resistor to.
BTW those wire & housing products are incredibly handy to have around.
dastels
by Dekaner on Sat Jul 11, 2020 11:19 am
Thanks! Something like this? Just cut the wire and then solder the resistor in between? I'll also pick up some heat shrink tubing to cover anything left exposed.
Premium Female/Female Jumper Wires - 20 x 6" (150mm)
PRODUCT ID: 1950
https://www.adafruit.com/product/1950
Should I worry about a single lead not having enough friction to keep it mounted? Would something like this be better as it would be more solid?
2mm Pitch 25-Pin Female Socket Headers - Pack of 5
https://www.adafruit.com/product/2672
Really appreciate your help.
Dekaner
by dastels on Sat Jul 11, 2020 12:52 pm
Well, that's 2mm pitch, and by the look of the board and your talking about the housings, I think you want .1" pitch. Be careful about that when ordering... I've been burned before by being sloppy about that sort of thing. Something like https://www.adafruit.com/product/4156 would work. They're easily trimmed if you pull out the pin and use wire cutters to snip where the hole is.
But yes, that will give you a much more solid physical and electrical connection.
dastels
