3992 (Medium Push-Pull Solenoid - 5V or 6V)
by dhirensahoo on Mon Jul 13, 2020 9:27 am
In my project i am planning to use part number :3992 (Medium Push-Pull Solenoid - 5V or 6V) . Near to this solenoid i am going to place magnetic Reed sensor .
but i am afraid if the solenoid is powered the solenoid coil , the electromagnetic field can be affect the operation of magnetic Reed sensor.
so i need some information for placement of sensor and 3992 solenoid
please inform
1) How much distance is require to maintain from Solenoid coil to reed sensor by which magnetic effect will not happen with reed sensor?
2) Can we use an metal cover / cage over the solenoid coil so that magnetic field will not interfere in the operation of reed sensor
3) if other method to follow for solenoid coil 3992 magnetic field
Please suggest the methods which will helpful for us to implement and reduce the magnetic field of solenoid coil
Thanks & Regards
Dhiren Sahoo
dhirensahoo
Re: 3992 (Medium Push-Pull Solenoid - 5V or 6V)
by adafruit_support_bill on Mon Jul 13, 2020 9:49 am
The solenoid is designed so that most of the magnetic field is contained within the frame. Additional iron or steel shielding could be added to help contain any stray flux lines.
How much it affects your reed switch would depend on the sensitivity of the reed switch and its orientation relative to the solenoid.
