LED power usage
LED power usage
by Derek_7 on Tue Jul 14, 2020 7:07 pm
I’m wanting to connect four 5mm LEDs together. One Green, one Red, and two white. The total voltage comes out to be 12.3V. If I connect this to a 9V battery, will the LEDs even turn on or will they just be very dim?
Derek_7
Re: LED power usage
by adafruit_support_bill on Tue Jul 14, 2020 7:12 pm
If you connect them all in series, you would probably get some light out of them.
If you want them at full brightness, you could wire them in parallel (or series-parallel) with appropriate current limiting resistors.
https://www.digikey.com/en/resources/co ... s-resistor
Re: LED power usage
by Derek_7 on Tue Jul 14, 2020 8:11 pm
Ok, one more question. Would it be possible to connect multiple resistors together. i.e. a 75 ohm and a 100 ohm in a parallel circuit.
Derek_7
Re: LED power usage
by adafruit_support_bill on Tue Jul 14, 2020 8:45 pm
You can have multiple resistor & led circuits wired in parallel. The resistor value for each circuit will depend on the forward voltage of the LED it is in series with.
