PowerBoost 1000c + Battery indicator wiring
by diogoq on Thu Jul 23, 2020 2:24 pm
Hi All,
I'm using a Power Boost 1000c from adafruit to power my Raspberry Pi project.
It will be battery powered obviously and i wanted to have a simple battery monitor like this attached.
I shorted the red button and connected this module to Bat and ground on the Power Boost and works fine. The problem is that even when the board is powered off via Enable pin the module is still powered because the Bat pin on the PowerBoost is directly connected to battery.
What is the risk of having the on/off switch directly on the battery wire instead of Enable pin so i can cut power completely from the board? I'm assuming current spikes when turning it on. If so how can i mitigate that or is it safe? Thanks
diogoq
Re: PowerBoost 1000c + Battery indicator wiring
by dastels on Thu Jul 23, 2020 4:14 pm
From the Product's tutorial (FAQ page):
Can I use the PowerBoost without a battery attached?
No. Please note that this board is designed to be used only with a LiPoly attached, it won't work without a battery.
dastels
by diogoq on Thu Jul 23, 2020 4:26 pm
Hi!
Thanks for the reply.
Ok, i could only charge the battery if turned on.
diogoq
by diogoq on Thu Jul 23, 2020 5:57 pm
For anyone interested i'm leaving the solution below.
For normal situation.
Sem Título2.png (44.2 KiB) Viewed 12 times
With LBO for low battery shutdown
Sem Título.png (62.52 KiB) Viewed 12 times
Follow instructions for setting up here.Link
diogoq
