Which perfboard can fit the small plastic enclosure without
by policenauts on Mon Jul 27, 2020 1:01 pm
I am interested in recreating what this person has done: https://www.hackster.io/saka/alexa-voic ... dvd-87fff1
It looks like it's a small Adafruit plastic enclosure: https://www.adafruit.com/product/903. And that he's taken a perfboard and attached it to the enclosure by screwing it into one of the middle holes.
My question is, which perfboards can fit this enclosure and also has a screw that lines up without modification?
I know that the perma proto board (which I love the look of) does fit, but it requires sanding down and also enlarging the hole which I don't want to do (like this person did: https://learn.adafruit.com/trinket-powe ... play/build). I'd also be interested in an enclosure that can fit the perma proto board without having to modify the perma protoboard.
Thank you!
policenauts
Re: Which perfboard can fit the small plastic enclosure with
by adafruit_support_mike on Wed Jul 29, 2020 12:53 am
If you don't want to do any modification at all, you'd probably have to use the 1/4 size Perma-proto:
https://www.adafruit.com/product/1608
by policenauts on Wed Jul 29, 2020 1:14 am
Thank you, but does the middle screw hole of the quarter size line up with the one in the small enclosure? Wouldn't I run into the same issue of having to shave down the corners?
Or is there a different enclosure that would work for the quarter size?
policenauts
by adafruit_support_mike on Wed Jul 29, 2020 4:05 am
You'd still have to trim the Perma-Proto to make the existing mounting holes fit the lugs in the enclosure, but you could use other ways to mount the board.. hot-melt gluing in a couple of new standoffs that fit the quarter-size board would be the simplest.
policenauts wrote:Or is there a different enclosure that would work for the quarter size?
The large enclosure will fit a full-size Perma-Proto:
https://www.adafruit.com/product/905
A half-size Perma-Proto will easily fit in either of our extruded aluminum enclosures or the transparent-topped tin:
https://www.adafruit.com/product/2229
https://www.adafruit.com/product/2230
https://www.adafruit.com/product/1471
And we have a Perma-Proto specifically designed to fit in an Altoids tin:
https://www.adafruit.com/product/723
https://www.adafruit.com/product/97
by policenauts on Wed Jul 29, 2020 9:53 am
Just the info I needed, thanks Mike!
policenauts
