Procedure Descriptions
by Owkmann on Mon Jul 27, 2020 2:54 pm
Are technical notes available that describe the use of Procedures or Functions in Adafruit's headers? For example,
"Serial.begin(9600);
Serial.println("RA8875 start");"
What are my options with the Serial procedure?
Or, what would you recommend as the easiest way to understand how this function works?
Stephen
Owkmann
Re: Procedure Descriptions
by westfw on Mon Jul 27, 2020 5:04 pm
There are essentially three levels of documentation for the Arduino functions (note that "Serial" is an Arduino thing, rather than an Adafruit-specific thing.)
1: There is the "Arduino Language Reference": https://www.arduino.cc/reference/en/lan ... on/serial/
2: There are many examples, and for more complex functions, there will usually be tutorials and/or discussions in the Arduino forums (or other forums.)
3: Read the source code. As far as I know, there isn't very much in the way of "internals documentation" of the sort you sometimes see in academia or "professional but not-really-helpful" vendor library documentation (like this Atmel ASF page) So for detailed information, you have to look at the actual code. Fortunately, that code is "open source" so that you CAN look at it, and is pretty readable.
westfw
by adafruit_support_carter on Mon Jul 27, 2020 5:20 pm
That looks like Arduino code.
The libraries can come from multiple locations, and thus the documentation will also be in multiple locations. There's a whole bunch of libraries that are part of the Arduino core, and Serial is one of them. So you can look here:
For any Adafruit Arduino library, there should be documentation at this location:
https://adafruit.github.io/<repo_name>
where you replace <repo_name> with the name of the github repository. For example, here's the Adafruit_RA8875 repo:
https://github.com/adafruit/Adafruit_RA8875
and here is the documentation:
https://adafruit.github.io/Adafruit_RA8875
