Timed LED Light On/Off, RTC, Relay, and Neopixels
by booyah323 on Wed Jul 29, 2020 9:52 am
Hey,
I'm new to programming and hardware so please take it easy on me. Also I absolutely need to solve this problem so if you won't help me please don't respond. I've programmed at time on/off circuit using this tutorial "https://www.instructables.com/id/Arduino-Ultra-Mega-Timers/". Really useful-I had to tweak some things though but it works. The problem is all I have to do is connect my lights to the 5v relay and I can have my lights turn on at any time of day and turn off at any time of day without being around. The problem is I'm using Adafruit Neopixel LED strips. They must be connected directly to the arduino which threw me off. Also, apparently have neopixels rids me of the need of a relay but if this is case-what sorts of adjustments are necessary to have the LEDs work with the rest of the circuit besides the relay. Like at midnight having the lights turn on by themselves.
This is the code (the relay function is at the end):
//Multiple Timer  RTC3231+LCD+Single Relay+Everyday+eeprom
#include <EEPROM.h>
#include <RTClib.h>
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
hd44780_I2Cexp lcd;//0x3F is my lcd address, maybe not yours!
RTC_DS3231 RTC;
#define HD44780_LCDOBJECT
//------Variables--------//
//------First Timer
byte onhour1;
byte onmin1;
byte onsec1;
byte offhour1;
byte offmin1;
byte offsec1;
//------Pages or menus
int page_counter=1;
int subpage1_counter=0;
int subpage2_counter=0;
//-------To convert clock into single number
unsigned long Time;
unsigned long Hour;
unsigned long Min;
unsigned long Sec;
//------To convert first timer into Single number
unsigned long on_Time1;
unsigned long on_hour1;
unsigned long on_min1;
unsigned long on_sec1;
unsigned long off_Time1;
unsigned long off_hour1;
unsigned long off_min1;
unsigned long off_sec1;
//-------Push buttons current/last state
boolean current_up = LOW;
boolean last_up=LOW;
boolean current_sel = LOW;
boolean last_sel = LOW;
boolean last_down = LOW;
boolean current_down = LOW;
//-------Pins
byte Relay =13;//Relay to pin 13
int up=2;      //Up button to pin 2
int sel=3;     //Select button to pin 3
int down=4;   //Down button to pin 4
//Custom return char
byte back[8] = {
  0b00100,
  0b01000,
  0b11111,
  0b01001,
  0b00101,
  0b00001,
  0b00001,
  0b11111
//Custom arrow char
byte arrow[8] = {
  0b01000,
  0b00100,
  0b00010,
  0b11111,
  0b00010,
  0b00100,
  0b01000,
  0b00000
  pinMode(Relay, OUTPUT);
     Wire.begin();
     RTC.begin();
     lcd.init();
     lcd.backlight();
     lcd.clear();
  lcd.createChar(1, back);//Custom chars
  lcd.createChar(2, arrow);
//--------eePROM  read values-------//
//------First Timer
onhour1=EEPROM.read(0);
onmin1=EEPROM.read(1);
onsec1=EEPROM.read(2);
offhour1=EEPROM.read(3);
offmin1=EEPROM.read(4);
offsec1=EEPROM.read(5);
   //---- De-bouncing function for all buttons----//
boolean debounce(boolean last, int pin)
boolean current = digitalRead(pin);
if (last != current)
delay(10);
return current;
current_up = debounce(last_up, up);         //Debounce for Up button
current_sel = debounce(last_sel, sel);      //Debounce for Select  button
current_down = debounce(last_down, down);   //Debounce for Down button
DateTime now = RTC.now();        // Clock call
now = RTC.now();
//-----Up/Down functions to move main pages------///
if(subpage1_counter==0 && subpage2_counter==0){ //up/down buttons enabled if subpages counters are 0,Disabled if 1,2..etc to work on submenus
//Page Up
    if (last_up== LOW && current_up == HIGH){ //Up button pressed
      lcd.clear();                            //Clear lcd if page is changed to print new one
      if(page_counter <3){                   //Page counter never higher than 3(total of pages)
      page_counter ++;                       //Page up
      else{
      page_counter= 1;                       //If higher than 3 (last page)go to main page
last_up = current_up;                   //Save up button last state
//Page Down
    if (last_down== LOW && current_down == HIGH){//Down button pressed
      if(page_counter >1){                      //Page counter never lower than 1
      page_counter --;                          //Page down
      else{
      page_counter= 3;                 //If lower than 1(first page)go to last page
    last_down = current_down;         //Save down button last state
//------------Pages and submenus display and control----------//
  switch (page_counter){
    case 1:                      //Content of main page
     last_sel=current_sel;  //Save last state of select button when we jump from the save screen
      lcd.setCursor(0,0);
      lcd.print("ULTRA MEGA TIMER");
      lcd.setCursor(0,1);
      lcd.print("TIME");
//--------Show  Time On LCD
lcd.setCursor(7,1);
if(now.hour() < 10)
lcd.print("0");
lcd.print(now.hour(), DEC); //Print hour
lcd.print(':');
if(now.minute() < 10)
lcd.print("0");
lcd.print(now.minute(), DEC); //Print min
lcd.print(':');
if(now.second() < 10)
lcd.print("0");
lcd.print(now.second(), DEC); //Print sec
    //case 1
    break;
    case 2:                   //Content and functions of page 2
      lcd.setCursor(0,0);
      lcd.print("T1");
      lcd.setCursor(3,0);
      lcd.print("ON");
      lcd.setCursor(1,1);
      lcd.write(byte(1));
      lcd.setCursor(3,1);
      lcd.print("OFF");
            lcd.setCursor(7,0);    //Printing on/off values
            if(onhour1<10){
              lcd.print("0");
            lcd.print(onhour1);
            lcd.setCursor(10,0);
            if(onmin1<10){
              lcd.print("0");
            lcd.print(onmin1);
            lcd.setCursor(13,0);
            if(onsec1<10){
              lcd.print("0");
            lcd.print(onsec1);
            lcd.setCursor(7,1);
            if(offhour1<10){
              lcd.print("0");
            lcd.print(offhour1);
            lcd.setCursor(10,1);
            if(offmin1<10){
              lcd.print("0");
            lcd.print(offmin1);
            lcd.setCursor(13,1);
            if(offsec1<10){
              lcd.print("0");
            lcd.print(offsec1);
//--------------Modifying on/off values-------//
     // Sub counter control
     if (last_sel== LOW && current_sel == HIGH){ //select button pressed
      if(subpage1_counter <7){                    // subpage counter never higher than 7 (total of items)
     subpage1_counter ++;                         //subcounter to move beetwen submenu
     else{                                       //If subpage higher than 7 (total of items) return to first item
      subpage1_counter=1;
     //First item control(subpage_counter =1) onhour1
     if(subpage1_counter==1){
     lcd.setCursor(0,1);         //Delete last arrow position (back)
     lcd.print(" ");
     lcd.setCursor(6,0);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(onhour1 < 23){
     onhour1 ++;
      else{
     onhour1 =0;
     last_up=current_up;
     if(last_down== LOW && current_down == HIGH){//Down
     if(onhour1 >0){
      onhour1 --;
     else{
      onhour1=23;
     last_down=current_down;
    }//subpage1_counter 1
     //Second item control(subpage_counter =2) onmin1
     if(subpage1_counter==2){
     lcd.setCursor(6,0);         //Delete last arrow position (onhour1)
     lcd.print(" ");
     lcd.setCursor(9,0);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(onmin1 < 59){
     onmin1 ++;
      else{
     onmin1 =0;
     last_up=current_up;
     if(onmin1 >0){
      onmin1 --;
     else{
      onmin1=59;
    }//subpage1_counter 2
     //Thirth item control(subpage_counter =3) onsec1
     if(subpage1_counter==3){
     lcd.setCursor(9,0);         //Delete last arrow position (onmin1)
     lcd.print(" ");
     lcd.setCursor(12,0);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(onsec1 < 59){
     onsec1 ++;
      else{
     onsec1 =0;
     last_up=current_up;
     if(onsec1 >0){
      onsec1 --;
     else{
      onsec1=59;
    }//subpage1_counter 3
     //fourth item control(subpage_counter =4) offhour1
     if(subpage1_counter==4){
     lcd.setCursor(12,0);         //Delete last arrow position (onsec1)
     lcd.print(" ");
     lcd.setCursor(6,1);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(offhour1 < 23){
     offhour1 ++;
      else{
     offhour1 =0;
     last_up=current_up;
     if(offhour1 >0){
      offhour1 --;
     else{
      offhour1=23;
    }//subpage1_counter 4
     //fifth item control(subpage_counter =5) offmin1
     if(subpage1_counter==5){
     lcd.setCursor(6,1);         //Delete last arrow position (offhour1)
     lcd.print(" ");
     lcd.setCursor(9,1);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(offmin1 < 59){
     offmin1 ++;
      else{
     offmin1 =0;
     last_up=current_up;
     if(offmin1 >0){
      offmin1 --;
     else{
      offmin1=59;
    }//subpage1_counter 5
     //sixth item control(subpage_counter =6) offsec1
     if(subpage1_counter==6){
     lcd.setCursor(9,1);         //Delete last arrow position (offmin1)
     lcd.print(" ");
     lcd.setCursor(12,1);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      if(offsec1 < 59){
     offsec1 ++;
      else{
     offsec1 =0;
     last_up=current_up;
     if(offsec1 >0){
      offsec1 --;
     else{
      offsec1=59;
    }//subpage1_counter 6
     //seventh item control(subpage_counter =7) back
     if(subpage1_counter==7){
     lcd.setCursor(12,1);         //Delete last arrow position (offsec1)
     lcd.print(" ");
     lcd.setCursor(0,1);          //Place arrow in front of selected item
     lcd.write(byte(2));
     //Move item + or -
      lcd.setCursor(0,1);         //Delete last arrow position (back) to exit
      lcd.print(" ");
     subpage1_counter=0;         //Exit submenu. Up/down butons enabled to move main pages
     last_up=current_up;
      lcd.print(" ");
     subpage1_counter=1;         //Go to first item (onhour1)
    }//subpage1_counter 7
    //case 2
    break;
    case 3:                //Page 3 display and functions
      lcd.setCursor(4,0);
      lcd.print("PRESS SEL");
      lcd.setCursor(5,1);
      lcd.print("TO SAVE");
     if (last_sel== LOW && current_sel == HIGH){  //select button pressed.Save settings to eeprom
  EEPROM.write(0, onhour1);
  EEPROM.write(1, onmin1);
  EEPROM.write(2, onsec1);
  EEPROM.write(3, offhour1);
  EEPROM.write(4, offmin1);
  EEPROM.write(5, offsec1);
  lcd.clear();                 //Print message "SAVED!"
  lcd.setCursor(5,1);
  lcd.print("SAVED!");
  delay(2000);
  lcd.clear();               //Clear lcd and go to main page
  page_counter=1;
    //Case 3
    break;
  }//switch
//-------------Conversion----------//
//---------Converting clock time into single number
Hour = now.hour();
Min = now.minute();
Sec = now.second();
Time = (Hour*10000+ Min*100 +Sec*1);
//--------Converting firt timer on/off into single number
on_hour1=onhour1;
on_min1=onmin1;
on_sec1=onsec1;
on_Time1=(on_hour1*10000 + on_min1*100 + on_sec1);
off_hour1=offhour1;
off_min1=offmin1;
off_sec1=offsec1;
off_Time1=(off_hour1*10000 + off_min1*100 + off_sec1);
//----Relay Function----//
if(onhour1 == offhour1 && onmin1==offmin1 && onsec1==offsec1){
   digitalWrite(Relay, LOW);
if(on_Time1 < off_Time1){
             if(Time >= on_Time1 && Time < off_Time1){  //Start
             digitalWrite(Relay, HIGH);
             else if(Time >= off_Time1) {
             else{
if (on_Time1 > off_Time1){
            if(Time >= on_Time1 && Time <= 235959){     //Start
            else if(Time < off_Time1 ){
            else if(Time >= off_Time1 && Time < on_Time1){
}//void loop
Thanks everyone!
booyah323
Re: Timed LED Light On/Off, RTC, Relay, and Neopixels
by dastels on Wed Jul 29, 2020 2:47 pm
With Neopixels, it's not just a matter of turning them on/off by controlling power to them. You need to set the color of each pixel (there's a fill function to do them all at once).
Simply turning them on & off will be a relatively simple change. Where you have relay control statements (the digitalWrite of Relay) you would fill the NeoPixel strip with (255, 255, 255) or (0, 0, 0). There is a small amount of code to set up the NeoPixels (not unlike the need to set up the relay output pin). See https://learn.adafruit.com/adafruit-neopixel-uberguide for a wealth of information on NeoPixels and their use.
dastels
by booyah323 on Thu Jul 30, 2020 9:09 pm
Hey,
Thanks for the reply- I read through the Adafruit Neopixel library and implemented the change you recommended. However, I have one last problem. The change to the code I inserted is actually messing with my LCD now. I'll post the snippet of code for the original relay function:
             else{
}//void loop
And the updated code for the Neopixels:
  if (onhour1 == offhour1 && onmin1 == offmin1 && onsec1 == offsec1) {
    pixels->clear();
    for (int i = 0; i < numPixels; i++) { // For each pixel...
      pixels->setPixelColor(i, pixels->Color(0, 0, 0));
      pixels->show();
      delay(DELAYVAL);
    if (on_Time1 < off_Time1) {
      if (Time >= on_Time1 && Time < off_Time1) { //Start
        pixels->clear();
          pixels->show();
          delay(8000);
          pixels->clear();
            pixels->setPixelColor(i, pixels->Color(255, 255, 255));
            pixels->show();
            delay(3);
      } else if (Time >= off_Time1) {
            pixels->clear();
              pixels->show();
              delay(DELAYVAL);
            else {
              pixels->clear();
                pixels->show();
                delay(DELAYVAL);
            if (on_Time1 > off_Time1) {
              if (Time >= on_Time1 && Time <= 235959) {   //Start
                pixels->clear();
                  pixels->show();
                  delay(8000);
                  pixels->clear();
                    pixels->show();
                    delay(3);
              }else if (Time < off_Time1 ) {
                    pixels->clear();
                      pixels->show();
                      delay(8000);
                      pixels->clear();
                        pixels->show();
                        delay(3);
                  }else if (Time >= off_Time1 && Time < on_Time1) {
                        pixels->clear();
                          pixels->show();
                          delay(DELAYVAL);
  }}//void loop
I made sure to confirm that the problem is absolutely the relay function code change and nothing else. I spent some hours trying to isolate the issue but I cannot figure this out. The relay function code just writes high or low power states to the 13th digital pin of my arduino at specific times dictated by my RTC. Why would changing that code affect my LCD? Here's the LCD code btw:
lcd.setCursor(7,1);
if(now.hour() < 10)
lcd.print("0");
lcd.print(':');
lcd.print("0");
lcd.print(':');
lcd.print("0");
    //case 1
    break;
      lcd.setCursor(0,0);
      lcd.print("T1");
      lcd.setCursor(3,0);
      lcd.print("ON");
      lcd.setCursor(1,1);
      lcd.write(byte(1));
      lcd.setCursor(3,1);
      lcd.print("OFF");
            if(onhour1<10){
              lcd.print("0");
            lcd.print(onhour1);
            if(onmin1<10){
              lcd.print("0");
            lcd.print(onmin1);
            if(onsec1<10){
              lcd.print("0");
            lcd.print(onsec1);
            lcd.setCursor(7,1);
            if(offhour1<10){
              lcd.print("0");
            if(offmin1<10){
              lcd.print("0");
            lcd.print(offmin1);
            if(offsec1<10){
              lcd.print("0");
            lcd.print(offsec1);
      subpage1_counter=1;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(onhour1 < 23){
     onhour1 ++;
      else{
     onhour1 =0;
     last_up=current_up;
     if(onhour1 >0){
      onhour1 --;
     else{
      onhour1=23;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(onmin1 < 59){
     onmin1 ++;
      else{
     onmin1 =0;
     last_up=current_up;
     if(onmin1 >0){
      onmin1 --;
     else{
      onmin1=59;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(onsec1 < 59){
     onsec1 ++;
      else{
     onsec1 =0;
     last_up=current_up;
     if(onsec1 >0){
      onsec1 --;
     else{
      onsec1=59;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(offhour1 < 23){
     offhour1 ++;
      else{
     offhour1 =0;
     last_up=current_up;
     if(offhour1 >0){
      offhour1 --;
     else{
      offhour1=23;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(offmin1 < 59){
     offmin1 ++;
      else{
     offmin1 =0;
     last_up=current_up;
     if(offmin1 >0){
      offmin1 --;
     else{
      offmin1=59;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      if(offsec1 < 59){
     offsec1 ++;
      else{
     offsec1 =0;
     last_up=current_up;
     if(offsec1 >0){
      offsec1 --;
     else{
      offsec1=59;
     lcd.print(" ");
     lcd.write(byte(2));
     //Move item + or -
      lcd.print(" ");
     last_up=current_up;
      lcd.print(" ");
    //case 2
    break;
      lcd.setCursor(4,0);
      lcd.setCursor(5,1);
  lcd.setCursor(5,1);
  delay(2000);
  page_counter=1;
    //Case 3
    break;
  }//switch
Hour = now.hour();
Min = now.minute();
Sec = now.second();
on_hour1=onhour1;
on_min1=onmin1;
on_sec1=onsec1;
off_hour1=offhour1;
off_min1=offmin1;
off_sec1=offsec1;
I'd really appreciate anyone who could point me in the right direction because I've hit a brick wall. By the way, the goal of the code is to make the light pulse 3 ms every 8 seconds.
Thank you.
booyah323
by dastels on Fri Jul 31, 2020 1:11 pm
The main thing I've seen is that you've replaced lines like
with things like
pixels->clear();
  pixels->show();
  delay(8000);
  pixels->clear();
    pixels->show();
    delay(3);
Which is very different!
It should be
pixels.fill(pixels.Color(255, 255, 255));
pixels.show();
dastels
