No longer can read from DHT22
by Radnor302 on Thu Jul 30, 2020 8:19 am
Hello to all!
I have a DHT22 connected to a RPi that WAS working....
I did an update / upgrade on the Pi and now cannot read the sensor.
  File "test.py", line 11, in <module>
    humidity, temp = get_inside_temp()
  File "test.py", line 7, in get_inside_temp
    localH, localT = Adafruit_DHT.read_retry(sensor, pin)
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 94, in read_retry
    humidity, temperature = read(sensor, pin, platform)
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 80, in read
    platform = get_platform()
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/common.py", line 60, in get_platform
    from . import Beaglebone_Black
  File "/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/Beaglebone_Black.py", line 24, in <module>
    from . import Beaglebone_Black_Driver as driver
ImportError: cannot import name 'Beaglebone_Black_Driver' from 'Adafruit_DHT' (/usr/local/lib/python3.7/dist-packages/Adafruit_DHT/__init__.py)
TIA for the help
Radnor302
Re: No longer can read from DHT22
by mikeysklar on Thu Jul 30, 2020 4:13 pm
I've seen another post on the forums that after a Pi was upgraded the platform_get() code is not returning a different chipset for the CPU hardware.
if it helps it looks like I ran a apt-get update / upgrade and it changed my CPUinfo to show that I have Hardware : BCM2711 I kinda hotwired platform_get() to treat that as a raspberry pi 3 and now it is working.... (I know this is a poor answer and poor solution but it fixed it.)
viewtopic.php?f=19&t=165722&p=821443&hilit=dht22+was+working#p821443
I would first try to run the following command to make sure you have the latest pip utilities and then re-install the DHT library.
sudo python3 -m pip install --upgrade pip setuptools wheel
sudo pip3 install Adafruit_DHT
I think this is most likely resolved, but only the OS has been upgraded not necessarily pip and the DHT library.
mikeysklar
by Radnor302 on Thu Jul 30, 2020 5:08 pm
Adafruit is at 1.4.0
How to go about patching the return value for the CPU???
cat /proc/device-tree/model
Raspberry Pi 4 Model B Rev 1.2
Hardware : BCM2711
Revision : c03112
Serial :
Model : Raspberry Pi 4 Model B Rev 1.2
Radnor302
by Radnor302 on Thu Jul 30, 2020 6:19 pm
found it and patched it
Radnor302
by mikeysklar on Thu Jul 30, 2020 8:34 pm
Cool - What was your solution?
mikeysklar
by Radnor302 on Thu Jul 30, 2020 10:07 pm
Radnor302
