Friction drive roller for Nema 17?
by octoshaw on Thu Jul 30, 2020 6:10 pm
Hi there.
I'm building a turntable project and am looking for a rubberized "friction roller"/"contact wheel" that will fit the 5mm shaft on my Nema 17 stepper motor - and yep, I'm aware that steppers are typically meant for timing pulleys or other more accurate drive connections :)
I've trawled Amazon and Aliexpress with no luck - maybe my search terminology is wrong? I did find some rollers on the Master-Carr site, but they are all non-metric shaft sizes (and surprisingly pricey). I need a 5mm shaft with set screw and about a 10mm tall, ~15mm diameter roller.
Any suggestions welcome!
Thanks.
octoshaw
Re: Friction drive roller for Nema 17?
by adafruit_support_mike on Fri Jul 31, 2020 1:22 am
One point of vocabulary: "NEMA-17" doesn't describe the motor, only the pattern of bolt holes on the faceplate.
Stock Drive Products calls the thing you want a 'feed roller':
https://shop.sdp-si.com/catalog/?cid=p1 ... view=table
They're another industrial supplier, and not cheap.
by octoshaw on Fri Jul 31, 2020 1:42 am
Thanks for the heads up Mike - was wondering about that.
Feed roller seem to do the trick.
Cheers!
octoshaw
