Xbox one analog stick replacement
by Texas1step on Sun Aug 02, 2020 3:17 pm
I play destiny and use an elite controller. And I'm tired of them wearing out so quickly. I am considering making my own, by using a stock controller and putting buttons on bottom, or using one of my 4 or 5 worn out elite controllers and replacing the the little green plastic tab/ buttons on board, with either your extended height tactle button, or your metal ball button mounted just under case. Anyway the worst thing about these controllers are the joysticks, and I was wondering if your 2 axis analog stick with switch would work in an xbox. Or your regular 2 axis joystick without switch,as I'm considering replacing the push down function "ie sprint and melee in destiny"with another button. Your regular 2 axis stick looks beefier because the potentiometer case is metal. Basically I was wondering if your sticks are sturdier then xbox sticks, and if they will function on an xbox.
Texas1step
