Adafruit HUZZAH ESP8266 Breakout WiFi serial
by Tom_in_AZ on Sat Aug 08, 2020 12:29 pm
I am using a Adafruit HUZZAH ESP8266 Breakout
PRODUCT ID: 2471 and need to access it via WiFi to connect to a YX5300 MP3 board.
My current sketch allows me to use the YX5300 board using the Arduino IDE connected through my FTDI usb board. It is functional this way (but can not be used this way for its intended purpose). I do not understand how to activate an Access Point on the huzzah board and get it to take commands from my phone via WiFi. How do I add the access point code and I guess software serial code into the same sketch to bring it all together?
Tom_in_AZ
Re: Adafruit HUZZAH ESP8266 Breakout WiFi serial
by Tom_in_AZ on Mon Aug 10, 2020 11:04 pm
Here is the code that I have uploaded to the Huzzah board via FTDI:
#include <SoftwareSerial.h>
// RX YX5300 MP3 Player Module <-----> TX(GPIO 4 / D2) SoftwareSerial NodeMCU ESP8266.
// TX YX5300 MP3 Player Module <-----> RX(GPIO 5 / D1) SoftwareSerial NodeMCU ESP8266.
SoftwareSerial mp3(5,4); //-> SoftwareSerial mp3 (RX_Pin, TX_Pin);
// ------------------------------------------------------- The byte commands are based on the table contained in the MP3 Player Module Document.
// Link to download the MP3 Player Module Document is available in the video description.
#define CMD_NEXT_SONG         0X01    //-> Play next song.
#define CMD_PREV_SONG         0X02    //-> Play previous song.
#define CMD_PLAY_W_INDEX      0X03    //-> Play with index.
// Play with index : 7E FF 06 03 00 00 01 EF -> Play the first song.
// Play with index : 7E FF 06 03 00 00 02 EF -> Play the second song.
#define CMD_VOLUME_UP         0X04    //-> Volume increased one.
#define CMD_VOLUME_DOWN       0X05    //-> Volume decrease one.
#define CMD_SET_VOLUME        0X06    //-> Set volume.
// Set volume : 7E FF 06 06 00 00 1E EF -> Set the volume to 30 (0x1E is 30) (Set volume is 06).
#define CMD_SNG_CYCL_PLAY     0X08    //-> Single Cycle Play.
// Single Cycle Play : 7E FF 06 08 00 00 01 EF -> Single cycle play the first song.
#define CMD_SEL_DEV           0X09    //-> Select device.
#define DEV_TF                0X02    //-> 02 for TF card.
// Select device : 7E FF 06 09 00 00 02 EF -> Select storage device to TF card.
#define CMD_SLEEP_MODE        0X0A    //-> Chip enters sleep mode
#define CMD_WAKE_UP           0X0B    //-> Chip wakes up
#define CMD_RESET             0X0C    //-> Chip reset
#define CMD_PLAY              0X0D    //-> Resume playback
#define CMD_PAUSE             0X0E    //-> Playback is paused
#define CMD_PLAY_FOLDER_FILE  0X0F    //-> Play with folder and file name.
// Play with folder and file name : 7E FF 06 0F 00 01 01 EF -> Play the song with the directory: /01/001xxx.mp3
// Play with folder and file name : 7E FF 06 0F 00 01 02 EF -> Play the song with the directory: /01/002xxx.mp3
#define CMD_STOP_PLAY         0X16    //-> Stop playing continuously.
#define CMD_FOLDER_CYCLE      0X17    //-> Cycle play with folder name.
// Cycle play with folder name : 7E FF 06 17 00 01 02 EF -> 01 folder cycle play
#define CMD_SHUFFLE_PLAY      0x18    //-> Shuffle play.
#define CMD_SET_SNGL_CYCL     0X19    //-> Set single cycle play.
// Set single cycle play : 7E FF 06 19 00 00 00 EF -> Start up single cycle play.
// Set single cycle play : 7E FF 06 19 00 00 01 EF -> Close single cycle play.
#define CMD_SET_DAC           0X1A    //-> Set DAC.
#define DAC_ON                0X00    //-> DAC On
#define DAC_OFF               0X01    //-> DAC Off
// Set DAC : 7E FF 06 1A 00 00 00 EF -> Start up DAC output.
// Set DAC : 7E FF 06 1A 00 00 01 EF -> DAC no output.
#define CMD_PLAY_W_VOL        0X22    //-> Play with volume.
// Play with volume : 7E FF 06 22 00 1E 01 EF -> Set the volume to 30 (0x1E is 30) and play the first song
// Play with volume : 7E FF 06 22 00 0F 02 EF -> Set the volume to 15(0x0f is 15) and play the second song
// Additional byte commands from several references. But I tried it on my module and it doesn't work. Maybe the module I'm using doesn't support these commands.
// Because the module that I use uses a chip AA19HFA440-94 (Although in the shop where this module was purchased writing YX5300 chip).
// Maybe these commands can work in modules with the YX5300 chip.
// Please comment in the comments column of this project video if these commands work or not in your module.
#define CMD_PLAYING_N         0x4C
#define CMD_QUERY_STATUS      0x42
#define CMD_QUERY_VOLUME      0x43
#define CMD_QUERY_FLDR_TRACKS 0x4e
#define CMD_QUERY_TOT_TRACKS  0x48
#define CMD_QUERY_FLDR_COUNT  0x4f
static int8_t Send_buf[8] = {0}; //-> Buffer to send commands.
static uint8_t ansbuf[10] = {0}; //-> Buffer to receive response.
// ------------------------------------------------------- Millis variables for receiving feedback data from the Serial MP3 Player Module.
unsigned long previousMillisCR = 0; //-> save the last time the data was received from the serial mp3 module.
const long intervalCR = 100; //-> interval for updating data received from serial mp3 player.
// ******************************************************************************************************* setup()
void setup(){
  Serial.begin(9600);
  mp3.begin(9600);
  delay(500);
  Serial.println("Hardware Serial dan Software Serial begin.");
  delay(500);
  Serial.println();
  Serial.println("Select storage device to TF card.");
  sendCommand(CMD_SEL_DEV, 0, DEV_TF);
  delay(500);
  printHelp();
  Serial.println();
// ******************************************************************************************************* loop()
void loop(){
  char c = ' ';
  // Incoming characters from the serial (Serial Monitor) are accommodated for processing and then sent to the mp3 player module.
  if ( Serial.available() ){
    c = Serial.read();
    sendMP3Command(c);
  unsigned long currentMillisCR = millis();
  if (currentMillisCR - previousMillisCR >= intervalCR) {
    // save the last time the data was received from the serial mp3 module.
    previousMillisCR = currentMillisCR;
    // Check response.
    if (mp3.available()){
      Serial.println(decodeMP3Answer());
// ******************************************************************************************************* printHelp()
// List of commands entered from the serial monitor.
void printHelp(){
  Serial.println("HELP  ");
  Serial.println(" h = Print again this Massage");
  Serial.println(" p = Play");
  Serial.println(" P = Pause");
  Serial.println(" > = Next");
  Serial.println(" < = Previous");
  Serial.println(" s = Stop Play");
  Serial.println(" + = Volume UP");
  Serial.println(" - = Volume DOWN");
  Serial.println(" c = Query current file");
  Serial.println(" q = Query status");
  Serial.println(" v = Query volume");
  Serial.println(" x = Query folder count");
  Serial.println(" t = Query total file count");
  Serial.println(" f = Play folder 1.");
  Serial.println(" S = Sleep");
  Serial.println(" W = Wake up");
  Serial.println(" r = Reset");
// ******************************************************************************************************* sendMP3Command
// Process and send commands entered from the serial monitor.
void sendMP3Command(char c) {
  switch (c) {
    case '?':
    case 'h':
      printHelp();
      break;
    case 'p':
      Serial.println("Play ");
      sendCommand(CMD_PLAY);
      break;
    case 'P':
      Serial.println("Pause");
      sendCommand(CMD_PAUSE);
      break;
    case '>':
      Serial.println("Next");
      sendCommand(CMD_NEXT_SONG);
      sendCommand(CMD_PLAYING_N); //-> Chek the file number that is playing
      break;
    case '<':
      Serial.println("Previous");
      sendCommand(CMD_PREV_SONG);
      break;
    case 's':
      Serial.println("Stop Play");
      sendCommand(CMD_STOP_PLAY);
      break;
    case '+':
      Serial.println("Volume Up");
      sendCommand(CMD_VOLUME_UP);
      break;
    case '-':
      Serial.println("Volume Down");
      sendCommand(CMD_VOLUME_DOWN);
      break;
    case 'c':
      Serial.println("Query current file");
      break;
    case 'q':
      Serial.println("Query status");
      sendCommand(CMD_QUERY_STATUS);
      break;
    case 'v':
      Serial.println("Query volume");
      sendCommand(CMD_QUERY_VOLUME);
      break;
    case 'x':
      Serial.println("Query folder count");
      sendCommand(CMD_QUERY_FLDR_COUNT);
      break;
    case 't':
      Serial.println("Query total file count");
      sendCommand(CMD_QUERY_TOT_TRACKS);
      break;
    case 'f':
      Serial.println("Playing folder 1");
      sendCommand(CMD_FOLDER_CYCLE, 1, 0);
      break;
    case 'S':
      Serial.println("Sleep");
      sendCommand(CMD_SLEEP_MODE);
      break;
    case 'W':
      Serial.println("Wake up");
      sendCommand(CMD_WAKE_UP);
      break;
    case 'r':
      Serial.println("Reset");
      sendCommand(CMD_RESET);
      break;
// ******************************************************************************************************* decodeMP3Answer()
// The meaning of the mp3 player module response
String decodeMP3Answer() {
  String decodedMP3Answer = "";
  decodedMP3Answer += sanswer();
  switch (ansbuf[3]) {
    case 0x3A:
      decodedMP3Answer += " -> Memory card inserted.";
      break;
    case 0x3D:
      decodedMP3Answer += " -> Completed play num " + String(ansbuf[6], DEC);
      break;
    case 0x40:
      decodedMP3Answer += " -> Error";
      break;
    case 0x41:
      decodedMP3Answer += " -> Data recived correctly. ";
      break;
    case 0x42:
      decodedMP3Answer += " -> Status playing: " + String(ansbuf[6], DEC);
      break;
    case 0x48:
      decodedMP3Answer += " -> File count: " + String(ansbuf[6], DEC);
      break;
    case 0x4C:
      decodedMP3Answer += " -> Playing: " + String(ansbuf[6], DEC);
      break;
    case 0x4E:
      decodedMP3Answer += " -> Folder file count: " + String(ansbuf[6], DEC);
      break;
    case 0x4F:
      decodedMP3Answer += " -> Folder count: " + String(ansbuf[6], DEC);
      break;
  return decodedMP3Answer;
// ******************************************************************************************************* sendCommand
// Function for sending commands.
void sendCommand(byte command){
  sendCommand(command, 0, 0);
void sendCommand(byte command, byte dat1, byte dat2){
  delay(20);
  Send_buf[0] = 0x7E;    //-> Every command should start with $(0x7E)
  Send_buf[1] = 0xFF;    //-> Version information
  Send_buf[2] = 0x06;    //-> The number of bytes of the command without starting byte and ending byte
  Send_buf[3] = command; //-> Such as PLAY and PAUSE and so on
  Send_buf[4] = 0x01;    //-> 0x00 = not feedback, 0x01 = feedback
  Send_buf[5] = dat1;    //-> data1
  Send_buf[6] = dat2;    //-> data2
  Send_buf[7] = 0xEF;    //-> Ending byte of the command
  Serial.print("Sending: ");
  for (uint8_t i = 0; i < 8; i++){
    mp3.write(Send_buf[i]) ;
    Serial.print(sbyte2hex(Send_buf[i]));
  Serial.println();
// ******************************************************************************************************* Functions for conversion
// For byte to hex conversion.
String sbyte2hex(uint8_t b){
  String shex;
  shex = "0X";
  if (b < 16) shex += "0";
  shex += String(b, HEX);
  shex += " ";
  return shex;
// For hex to integer conversion.
int shex2int(char *s, int n){
  int r = 0;
  for (int i=0; i<n; i++){
     if(s[i]>='0' && s[i]<='9'){
      r *= 16;
      r +=s[i]-'0';
     }else if(s[i]>='A' && s[i]<='F'){
      r *= 16;
      r += (s[i] - 'A') + 10;
  return r;
// ******************************************************************************************************* sanswer(void)
// Function: sanswer. Returns a String answer from mp3 UART module.
// Parameter:- uint8_t b. void.
// Return: String. If the answer is well formated answer.
String sanswer(void){
  uint8_t i = 0;
  String mp3answer = "";
  // Get only 10 Bytes
  while (mp3.available() && (i < 10)){
    uint8_t b = mp3.read();
    ansbuf[i] = b;
    i++;
    mp3answer += sbyte2hex(b);
  // if the answer format is correct.
  if ((ansbuf[0] == 0x7E) && (ansbuf[9] == 0xEF)){
    return mp3answer;
  return "???: " + mp3answer;
Tom_in_AZ
by Tom_in_AZ on Fri Aug 21, 2020 10:56 pm
Can I please at least get a copy of the factory stock BIN file that this board ships with? I need to start from scratch with this board as now I'm getting exceptions.
Tom_in_AZ
