Low speed clock
Low speed clock
by oxim5 on Tue Aug 24, 2010 5:00 pm
Hi I am looking for a simple way to have a clock about 16 - 20 khz board real estate is limited so it must be small. also I would like to keep the component count to a minimum. I have always used ceramic oscillators. I never really designed any clocks. this clock will be used to drive some TTL chips at 5V.
Thanks for your help
oxim5
Re: Low speed clock
by richms on Wed Aug 25, 2010 1:10 am
The norm for timekeeping clocks is 32768Hz, since you can divide down easily to 1 Hz. you could just divide by 2 to get the approx 16kHz that you need.
Those should be readily available with schematics etc if you have a look around.
richms
Re: Low speed clock
by oPossum on Wed Aug 25, 2010 2:14 am
A couple of inverting gates (inverter, NAND, NOR, XOR) can be used to make a simple oscillator.
A Schmitt trigger gate (74HC14 or similar) only requires one inverter.
I am the Possum, and I approve of this message. Sent from MacBook Wheel Sorry for my bad German.
oPossum
Re: Low speed clock
by oxim5 on Wed Aug 25, 2010 9:23 am
Thanks for the tips. It was exactly what I needed!
Are those value used in the 2 gate clock just an example or will that give me 20-16 khz?
oxim5
