Bit masking?
Bit masking?
by rizla420 on Wed Aug 25, 2010 10:19 am
Whats the best way to go about inverting all the bits in a byte of a variable and copying the result to another.
something like:
byte original_var=10101010;
byte bit_mask=00000000;
output_var=original_var & bit_mask;
//im assuming the output_var should have this value. Do i have to loop through the mask, or just by having it expressed the way i have it should have the expected result?
output_var=01010101;
I cant check my code now , but just wanted to see if thats the proper way to do it.
rizla420
Re: Bit masking?
by adafruit_support_bill on Wed Aug 25, 2010 10:32 am
'~' is the bitwise NOT operator in C/C++.
as in:
output = ~input;
Re: Bit masking?
by rizla420 on Wed Aug 25, 2010 10:55 am
arduwino wrote:'~' is the bitwise NOT operator in C/C++.
as in:
output = ~input;
I just read that on the arduino page.. that is such a helpful operator. Thanks!
rizla420
Re: Bit masking?
by pstemari on Wed Aug 25, 2010 11:59 am
Alternatively, you can use ^ (XOR) to flip individual bits, e.g.
byte x = 0x5A;
x ^= 0x0F;
x = 0x55;
--Paul
A wholly owned subsidiary of:
Persephone: DL R+W+B C 7 X L W C++ I++ T+ A E H++ S+ V-- F+ Q P B PA+ PL
Aldebaran: DM Rt H 5 Y L- W+ C+ I++ T++ A+++ E H++ S+ V+ F++ Q+ P B++ PA- PL--
pstemari
Re: Bit masking?
by rizla420 on Wed Aug 25, 2010 12:29 pm
pstemari wrote:Alternatively, you can use ^ (XOR) to flip individual bits, e.g.
byte x = 0x5A;
x ^= 0x0F;
x = 0x55;
I thought that was what the ~ did.. hm i'll have to compare the output of both. I just need to flip the bits in a byte value, one of one. Perferably without have to loop through each bit in the byte.
rizla420
Re: Bit masking?
by westfw on Wed Aug 25, 2010 12:47 pm
"~" ("not") inverts all the bits in the argument. "^" ("exclusive or") will only invert the bits that are the same in both arguments:
~1 == 0
~0 == 1
1 ^ 0 == 1
1 ^ 1 == 0
0 ^ 0 == 0
0 ^ 1 == 1
This allows you to select only some bits in a variable to be inverted:
result = var ^ bitmaskOfBitsToBeInverted;
(leaving the bits that weren't 1s in the bitmask the same as they were.)
westfw
Re: Bit masking?
by rizla420 on Wed Aug 25, 2010 12:56 pm
westfw wrote:"~" ("not") inverts all the bits in the argument. "^" ("exclusive or") will only invert the bits that are the same in both arguments:
~1 == 0
~0 == 1
1 ^ 0 == 1
1 ^ 1 == 0
0 ^ 0 == 0
0 ^ 1 == 1
Thanks westfw for the clarification. So the NOT operator does an exact inversion of all the bits. The XOR relies upon a second argument as a comparator to decide which bits to flip. Sound about right?
rizla420
Re: Bit masking?
by zener on Wed Aug 25, 2010 1:25 pm
Yes. Wherever there is a "1" in the mask, it flips that bit. I think this is what you are wanting. Yes?
zener
Re: Bit masking?
by rizla420 on Wed Aug 25, 2010 1:45 pm
Zener wrote:Yes. Wherever there is a "1" in the mask, it flips that bit. I think this is what you are wanting. Yes?
Yea, but i really wasn't going to be using a mask. I just thought thats how you had to do it, similar to network subnetting. I just needed a way to invert the bits of a byte. If the value is 1 change to 0, vice versa. So i think the NOT operator is more so what i'm looking for rather than the XOR.
rizla420
