Basic 5V supply parts pack Breadboarding help
by Tooliktman^ on Wed Aug 25, 2010 2:04 pm
i need help on how to breadboard the basic 5V supply parts pack. if anyone have a clear schematic layout to send i will be grateful.
Tooliktman^
Re: Basic 5V supply parts pack Breadboarding help
by adafruit_support_bill on Wed Aug 25, 2010 2:31 pm
by Tooliktman^ on Wed Sep 01, 2010 10:30 am
Hi i made it!
it emits 5 volts from the left +- column and 9 volts from the right +- column of the breadboard is it ok?
I would like to know how many Ampere it can emit.
Thank you :)
Tooliktman^
by adafruit_support_bill on Wed Sep 01, 2010 10:38 am
Good job! :)
Yes, the circuit shown will put out 5v on the left and 9v on the right. The 7805 regulator for the 5v side will handle up to 1A, but that assumes that your 9v input can provide that much. If you are using the Adafruit 9v wall-wart supply, that is rated for 660mA.
by zener on Wed Sep 01, 2010 1:31 pm
Keep in mind there is a power limit also, which has a lot to do with your heat sink on the regulator (if any). Without a good heat sink you will likely not be able to do 1A. You calculate the watts by: (Vin-Vout)*(current). Then you can figure out your theta in degC per watt if you want to be really fancy...
zener
by Tooliktman^ on Thu Sep 02, 2010 4:59 am
Ok thank you,
Anyone know if is possible to charge usb things with this power supply? and what are the pin to connect to do this? :?
Tooliktman^
by adafruit_support_bill on Thu Sep 02, 2010 7:39 am
5v is a good start for a usb charger. But different devices have different requirements for charging. Check out the MintyBoost pages for more information.
