needed circuit diagram
by cybersnake81 on Sun Sep 26, 2010 11:42 pm
I am looking for a circuit board or a diagram.............what I am needing is a 9 volt battery charged by usb and put out 5 volts
cybersnake81
Re: needed circuit diagram
by franklin97355 on Mon Sep 27, 2010 1:17 pm
You will need to have a boost regulator to charge and a buck to supply 5v. You also need a rechargable battery and most 9v batteries are not.
franklin97355
by neutron spin on Mon Sep 27, 2010 10:49 pm
There are both Lithium and NiMH rechargeable 9 volt Batteries. What is the battery application? The 9 volt package does not have a real high capacity.
neutron spin
by cybersnake81 on Mon Sep 27, 2010 10:57 pm
I am wanting a battery that will last a long time .............what do you suggest I can use?
cybersnake81
by adafruit_support_bill on Tue Sep 28, 2010 6:01 am
What are you going to power with it? A standard 9v will power a DMM for a year or two. Or a motor for a couple of minutes if you are lucky.
Are there any constraints on size? You can get 9v rechargeable battery packs in many different sizes. Generally, high capacity packs are going to be larger.
by zener on Tue Sep 28, 2010 2:15 pm
Why 9V?
zener
by cybersnake81 on Tue Sep 28, 2010 10:12 pm
ok I don't know much about batteries I was looking for something that will last awhile but still kinda small ok this is what it is if anyone knows what a electronic cigerette is I am looking to build what they call a box mod but I want it to be safe and not blow up in my face and I want it to put out five volts and recharge it using a usb port so I don't have to pull out the batteries to charge them so far thank you all for your help
cybersnake81
