Led ring on a glue gun, help needed.
by TruckMechanic on Wed Jan 20, 2021 2:43 pm
Hi, I'm a mechanic and I would like to improve my electric glue gun. I'm thinking of installing a led ring around the nozzle of the gun to get better visibility when applying black glue on black surfaces.
The gun has a 18V battery but I'm not planning to use this as a power-source straight away. I want to test the lighting first and if it works good I consider installing a buck converter. My plan is to use a small USB powerbank to start with. The whole system has to be as light and compact as possible since the gun is already pretty heavy. Also I need some sort of quick disconnect between the Led ring and the rest of the system, I'm not sure which connector I should use. I have to disconnect it every time I use it.
I've been doing some research, but I got lost in all the possibilities along the way.
Here's what I've come up with so far:
The Neopixel 16 RGB ring would fit perfectly around the nozzle. I don't really need the colors, but if my glue gun can perform some discrete disco light-show it sure can put some sparks in the work :-) I know the RGBW ring would be better, but where I live it's hard to lay my hands on and it's more expensive. Considering the fact it might get some PU-glue on it, the cheaper the ring the better. My only concern is if I can get some sort of "decent" white light from the RGB ring. It doesn't have to be perfect white light, just something I can work with.
Next thing I'm confused about is the controller. I was thinking to use the 5V Trinket (1501), but I'm not sure if this is the right choice. I want it to be as compact as possible, not to get in my way when using it. I only need white light and maybe a cool startup light-show. I'm not a coding expert by far, so the easier the better.
It would also be nice to have an on/off switch with the possibility to toggle between various light sequences, but I'm not sure which switch to use and if/how this would be possible with a small controller.
The main goal is to have better visibility when applying glue. Extra "sparks" are cool and very welcome, but the whole system has to be light, simple and easy to work with. I have plenty tools available and have some experience in electrical work, however I'm a complete novice with prototyping and coding.
Can you guys help me out? All your thoughts and advice are more then welcome. I'll try to post some pics in the next couple of days so you can get a better idea of what I need.
Thanks in advance :-)
