Magtag Import Error
Magtag Import Error
by geersy on Sun Jan 31, 2021 9:27 pm
I've tried a couple different projects with the Magtag that came with Adabox 017, but keep getting this error when loading up:
code.py output:
File "code.py", line 7, in <module>
File "adafruit_magtag/magtag.py", line 32, in <module>
File "adafruit_portalbase/__init__.py", line 28, in <module>
ImportError: no module named 'adafruit_display_text.wrap_text_to_lines'
I've tried to re-load CircuitPython and the libraries, digging through the folders, and can't find a solution. Any help would be great, thank you.
geersy
Re: Magtag Import Error
by dastels on Sun Jan 31, 2021 10:29 pm
Delete everything in CIRCUITPY/lib and empty trash. Then recopy the libraries/modules you need. That usually does the job.
dastels
by geersy on Sun Jan 31, 2021 10:51 pm
dastels wrote:Delete everything in CIRCUITPY/lib and empty trash. Then recopy the libraries/modules you need. That usually does the job.
That worked! Thank you so much!
geersy
by cnorcom on Fri Jun 11, 2021 1:51 pm
Hello! I thought I would add that I am having the same issue. I have tried uploading libraries from the project lib folder I'm using and from the adafruit circuit python bundle. I've deleted the libraries completely and uploaded them and tried adding them one at a time and I till get the "no module named 'adafruit_magtag' error.
It's there - I can see it! I don't know why the program can't.
Thank you!
cnorcom
by cnorcom on Fri Jun 11, 2021 2:35 pm
I also just tried re-flashing the .uf2 from a second computer with a different operating system before deleting and uploading the files. I'm still having the same issue.
cnorcom
by dastels on Fri Jun 11, 2021 4:06 pm
Did you copy the adafruit_magtag folder to CIRCUITPY/lib?
dastels
by cnorcom on Fri Jun 11, 2021 4:40 pm
Yes. About 6 or 7 times now from different computers with different operating systems.
cnorcom
by dastels on Fri Jun 11, 2021 5:21 pm
Where you copy from shouldn't matter. Neither should copying repeatedly. Can you post exactly what's on CIRCUITPY and CIRCUITPY/lib? I.e. a screenshot or copy/paste.
dastels
