Simple RF Receiver issue
by monkeyboys on Wed Apr 14, 2021 4:27 pm
I'm using the Simple RF Receiver Momentary M4 type and it is working, but in reverse. The LEDs are always lit and a press of the keyfob momentarily turns them off. I'm guessing something is just wired funny but I don't know what. Pic attached.
monkeyboys
Re: Simple RF Receiver issue
by adafruit_support_mike on Mon Apr 19, 2021 7:56 pm
You have one end of the LED connected to the 5V rail instead of GND. Try moving that connection to GND.
by m_g on Sat Jun 12, 2021 6:50 pm
Simple RF M4 Receiver - 315MHz Momentary Type PRODUCT ID: 1096
The product info reads:
"The M4 momentary type acts like a push button - when the A button is held down, the matching pin goes high. When the A button is released, the matching pin goes low. The pins only go high when a button is pressed"
The pins depicted in the photos are:
GND +5V D0 D1 D2 D3 DT
Which pin goes low when the A button is held down?
Thank you.
m_g
by adafruit_support_mike on Mon Jun 14, 2021 9:04 pm
D0.
by m_g on Wed Jun 16, 2021 7:33 pm
Thanks adafruit_support_mike
m_g
by Disciple on Fri Jun 18, 2021 9:26 am
m_g wrote:Which pin goes low when the A button is held down?
I bought a couple of these a while ago and they behave differently. When I press the A button, all of the signal pins stay low except for VT and D3. The numbered D# pins go high in response to the four key fob buttons in reverse order, so button D activates pin D0. Pin VT responds to any button. I thought that new receivers would still behave in the same way, but I might be wrong.
Hallelujah!
Disciple
Disciple
