Adafruit Motor Shield V2 and Wemos D1 R32
PaudC100
Post by PaudC100 »
Hi, I have an arduino UNO working successfully with a stepper motor using an adafruit motor shield v2. I am now trying to migrate the project to a Wemos D1 R32. My stepper motor is unresponsive when connected. This page https://www.letscontrolit.com/wiki/inde ... ield_v2%22 says "To connect it to ESP8266 devices (e.g. Wemos D1 R2) you have to set it to 3.3 V, see adafruit documentation for that." I have cut the link between 5v and the logic pad, then soldered logic pad to 3v but there is still no life in the stepper?
Re: Adafruit Motor Shield V2 and Wemos D1 R32
Please post some photos showing your wiring and connections.
PaudC100
Post by PaudC100 »
Thanks for your reply. Managed to get it working. Took everything apart and reassembled. Resoldered 5V pad to logic pad and everything is good
Good to hear it's working. Thanks for the update.
wadwin
Post by wadwin »
PaudC100 wrote:Thanks for your reply. Managed to get it working. Took everything apart and reassembled. Resoldered 5V pad to logic pad and everything is good
Hi PaudC100,
I have exactly the same problem,
Can you give me more details about your fix ?
dada4302
Post by dada4302 »
Have somebody the solution ?
I have exactly the same problem...
wadwin
Post by wadwin »
I have dound that : To connect it to ESP8266 devices (e.g. Wemos D1 R2) you have to set it to 3.3 V, see adafruit documentation for that.
Is it the solution ? how to do that ?
Can somebody help me please ?
Converting to 3.3v operation is covered in the FAQ: https://learn.adafruit.com/adafruit-mot ... aq-2861877
wadwin
Post by wadwin »
Thx for answer,
I don't understand the reason of the problem,
The shield comes configured by default to use 5v logic signals. This is appropriate when used with 5v processors such as the Arduino UNO. The shield needs to be re-configured to use 3.3v logic when used with 3.3v processors.
wadwin
Post by wadwin »
Hi Bill,
Thank for your answer,
Is it possible to reconfigure motorshield V2 to use 3.3V logic ?
Near the 3v and 5v pins, there is a set of jumper pads labeled "logic" 3v 5v".
Cut the thin trace between the center pad and the 5v pad. Then use solder to bridge between the center and the 3v pad.
wadwin
Post by wadwin »
Thank a lot
You can close the topic :)
wadwin
Post by wadwin »
convert motorshield v2 5v to 3v logic by soldering
convert motorshield v2 5v to 3v.jpg (377.16 KiB) Viewed 611 times
wadwin
Post by wadwin »
Hope my photoshop will help somebody :)
Thx for all
<3
