Switch Mode Power Supply Tutorial
by kevinm on Thu Oct 28, 2010 12:46 pm
Not sure if this is the place to post this but...
Hackaday had a post (http://hackaday.com/2010/10/27/power-su ... xperience/) about your power supply tutorial (http://www.ladyada.net/learn/powersupply/index.html).
Before you get to the switch mode power supply tutorial you should check out the power integration LNK501PN. I used this about 5 years ago and it was the lowest cost solution I could find. The chips are available at mouser and digikey for under $1.50 single piece and under $0.75 in high quantities. The power integrations web site has a link to get the transformer samples quickly. Here's a link to the charger reference design I used (PDF) http://www.powerint.com/sites/default/f ... s/di18.pdf
-Kevin
kevinm
Re: Switch Mode Power Supply Tutorial
by Hfuy on Thu Oct 28, 2010 5:49 pm
I can only direct you to my "SMPS are outrageously twitchy" thread.
They are. I just bought a switching LED driver off the shelf, and even that just gets hot and makes smells!
Hfuy
by pstemari on Mon Nov 08, 2010 10:50 pm
Hmm, hadn't read that tutorial before. I'll point out that two diodes and a center tap isn't really full wave rectification--only one half of the transformer secondary is used at a time.
--Paul
A wholly owned subsidiary of:
Persephone: DL R+W+B C 7 X L W C++ I++ T+ A E H++ S+ V-- F+ Q P B PA+ PL
Aldebaran: DM Rt H 5 Y L- W+ C+ I++ T++ A+++ E H++ S+ V+ F++ Q+ P B++ PA- PL--
pstemari
by oPossum on Mon Nov 08, 2010 11:56 pm
It is full wave, half bridge.
Both halves of the cycle are used, so it's not half wave.
I am the Possum, and I approve of this message. Sent from MacBook Wheel Sorry for my bad German.
oPossum
by stinkbutt on Tue Nov 09, 2010 1:32 am
Plus, it hardly matters if you don't use the full capacity of the transformer if you're just going to dump the output into the boost and/or buck converter anyway.
Red M&M, Blue M&M: They all wind up the same color
stinkbutt
