Adafruit micro cam with trigger
by ingfried13 on Sun May 02, 2021 2:16 pm
Hello guys, I bought a micro camera with trigger from you, and in the micro sd slot I inserted a micro sd to sd adapter, then in the SD slot I inserted a sd wifi card, but the problem is that I believe the SD wifi card is not getting any feed because I cannot see the wifi network from the SD wifi card, instead when I insert the SD wifi card in a conventional digital camera, I can see the SD wifi network. I need something that feeds the SD card that receive the info from the camera and send the photos to the SD wifi card, can you please help me?
ingfried13
Re: Adafruit micro cam with trigger
by ingfried13 on Mon Jun 14, 2021 12:29 am
I have not received any reply from you, why did you set the communication via your forum if you are not going to reply at all???
ingfried13
by adafruit_support_carter on Mon Jun 14, 2021 1:19 pm
The camera may not support that. Have you tried recording to a standard SD card? (make sure it's FAT32)
