Adafruit MPU-6050 6-DoF Accel and Gyro Sensor MAX INPUT VOLT
by dimigaro on Mon May 03, 2021 5:49 am
Hi, I need to know if the Adafruit MPU-6050 6-DoF Accel and Gyro Sensor (3886) can be powered with 5.5V. Technical specifications of the component do not say so.
dimigaro
Re: Adafruit MPU-6050 6-DoF Accel and Gyro Sensor MAX INPUT
by adafruit_support_bill on Mon May 03, 2021 6:57 am
The board is designed and tested to work with a 3v-5v power source: https://learn.adafruit.com/mpu6050-6-do ... -3044770-2
Looking at the data sheet for the regulator on the board: The maximum recommended supply voltage is 6v, so in theory, it should work with 5.5v.
https://www.diodes.com/assets/Datasheets/AP2112.pdf
by dimigaro on Mon May 03, 2021 6:58 am
Great, thanks!
dimigaro
by adafruit_support_bill on Mon May 03, 2021 7:34 am
Note that SDA and SCL are both pulled high to VCC. So if powering with 5.5v, make sure that your microcontroller can handle 5.5v on the i2c bus.
