Pygamer MP3-player
Pygamer MP3-player
by Lirik on Mon May 03, 2021 4:44 pm
Hello! I've got a proble while following this guide.
The problem was at last step - playing the audio. It just frozen. I have CircuitPython 6
And only in circuitpython 5.3 it shows readable message:
line 400, in change_stream
OSError:[Errno 5] Input/output error
I didn`t change enything in original script, just copied files as is. So for now following your guide it will show this message on CP v5.3 or just frozen with no errors on CP 6.2
How to fix it?
Lirik
Re: Pygamer MP3-player
by adafruit_support_carter on Tue May 04, 2021 2:58 pm
I just tried this with latest everything and it worked here.
Are you getting the CircuitPython firmware from here?
https://circuitpython.org/board/pygamer/
And to get the MP3 player and associated files, are you using the Download Project Bundle button?
by Lirik on Tue May 04, 2021 6:41 pm
Yes, of course. Literally followed the guide
Lirik
by adafruit_support_carter on Tue May 04, 2021 7:01 pm
If you remove the SD card and run it, do you at least get the message on the screen that says no sd card found?
by Lirik on Tue May 04, 2021 8:48 pm
adafruit_support_carter wrote:If you remove the SD card and run it, do you at least get the message on the screen that says no sd card found?
yes. Everything is fine untill I will not choose folder for playing songs.
Then I see song playing screen, but nothing happpens and device also frozen in total commander too, noway to copy something.
Even navigation between player's buttons by pygamer joystick doesn't work.
After ~1 minute device is automatically disconnected, and after 10 secs again automatically reconnected but as undefined. (look at the picture)
download/file.php?mode=view&id=83411
Comes to normal only after manual reset.
So this gonna happen every thime
undefined device
Снимок экрана 2021-05-05 034311.png (9.18 KiB) Viewed 67 times
Lirik
by adafruit_support_carter on Tue May 04, 2021 9:04 pm
OK, it may be related to something with the SD card then. Do you have another SD card you could try?
by Lirik on Wed May 05, 2021 1:55 pm
64 GB. Mp3-player can`t see it. Does it has some requierments? Maybe formatting partition to NTFS/FAT/ext?
Updated. Found another 16gb card. Yes, it works.
Thats strange, cause this card is older :D
And NES emulator worked exellent.
Lirik
by adafruit_support_carter on Wed May 05, 2021 2:54 pm
Yes, it needs to be a FAT partition. Not exFAT, which a 64G card might be.
by Lirik on Wed May 05, 2021 2:59 pm
adafruit_support_carter wrote:Yes, it needs to be a FAT partition. Not exFAT, which a 64G card might be.
Ok, I`ll try it, thanks.
Thread can be closed, if it can be.
Lirik
