Relay FeatherWing Signal
by EmilyJackson on Thu May 06, 2021 5:12 pm
I have the non-latching featherwing relay signal hooked up to my feather proto M0 pin 13. I'm not getting a voltage when measuring the output terminal block, and the signal LED is not turning on. However, I do get a voltage measurement from the signal port at the appropriate time according to my code. Could this mean I've fried something on the relay board or that I'm missing something in my Arduino sketch? If I've fried something, is there something I can do to avoid doing it again?
The basic code is :
int UVC1 = 13;
pinMode(UVC1, OUTPUT);
digitalWrite(UVC1, LOW);
if ... {
digitalWrite(UVC1, HIGH);
delay(1000);
EmilyJackson
Re: Relay FeatherWing Signal
by dastels on Thu May 06, 2021 5:48 pm
The 3v connection needs to be connected to the feather as well. It's used to power both the light and the relay.
You won't get any voltage on the output terminal block; the relay is simply a double throw switch. When the relay isn't powered COM and NC are connected. When it's powered COM and NO are connected.
dastels
