5mm Chromed Metal Narrow Bevel LED Holder question, pn 2176
by m2grapefruit on Fri May 07, 2021 11:23 am
We've purchased a 5mm Chromed Metal Narrow Bevel LED Holder kit using tri-color LEDS (4 leads). However, the plastic "corks" are configured for 2 lead devices.
My question is: Do you have plastic "corks" that can accommodate 4 lead LED's (4 holes vs. 2 holes).
m2grapefruit
Re: 5mm Chromed Metal Narrow Bevel LED Holder question, pn 2
by mikeysklar on Sat May 08, 2021 9:34 pm
I believe product# 2173 is the one you are looking for with the plastic 4-pin popouts.
https://www.adafruit.com/product/2173
mikeysklar
by m2grapefruit on Mon May 10, 2021 8:45 am
Mike,
Thanks for the quick reply, albeit it appears these are 8mm vs the 5mm size we require. Also, these are discontinued.
Are there any other options available that you might suggest?
m2grapefruit
by mikeysklar on Mon May 10, 2021 5:39 pm
My apologies. I had noticed there were 8mm and 5mm 4-pin plastic options. I meant to send you the 5mm. These are in-stock.
https://www.adafruit.com/product/2178
mikeysklar
