Propmaker lightsaber additional switches
by BJCM on Sat May 08, 2021 10:32 pm
I am trying to plan out the wiring for 2 additional momentary buttons on the Propmaker mounted on an M4. I know I need to wire one side of each button to separate, unused digital pins. However, what pin does the other side of the button connect to so it will register the button press?
BJCM
Re: Propmaker lightsaber additional switches
by dastels on Sun May 09, 2021 9:54 am
Ground.
Then in the code you set that pin as an input with a pullup. Seeing LOW/False/0 on the pin means the button is pressed.
dastels
by BJCM on Sun May 09, 2021 10:08 am
Thank you for the quick and helpful reply.
BJCM
