Playground Bluefruit + NFC
by kinkadius on Mon Jun 07, 2021 7:33 pm
The Adafruit Playground Bluefruit uses the Nordic NRF52840 SoC, which contains support for bluetooth/wifi as well as NFC.
Is it correct to assume that the "Micro NFC/RFID Transponder - NTAG203 13.56MHz" can be used to access NFC features on Adafruit Playground Bluefruit? Here's a link to the product in mind:
https://www.adafruit.com/product/2800
Has anybody tried this on the bluefruit board before? Do I require any other hardware if NFC is supported on the NRF52840?
kinkadius
Re: Playground Bluefruit + NFC
by adafruit_support_mike on Mon Jun 07, 2021 9:42 pm
The nRF52840 has firmware and radios that can handle NFC, but you'd still need an antenna coil. None of our nRF52840 boards can do NFC.
by kinkadius on Wed Jun 09, 2021 11:26 am
adafruit_support_mike wrote:The nRF52840 has firmware and radios that can handle NFC, but you'd still need an antenna coil. None of our nRF52840 boards can do NFC.
Can I use this for the antenna coil below, then connect to GPIO to use?
kinkadius
by adafruit_support_mike on Thu Jun 10, 2021 6:38 pm
No, that's an NFC tag, not an NFC reader.
