Couldn't find any more appropriate place to put this...
Found (what I believe to be) a bug in the Zero_Timer-master code:
*** 442,449 ****
return false;
_pwm_channel[channum].enabled = true;
! _pwm_channel[channum].pin_out = pin;
_pwm_channel[channum].pin_mux = pinmux;
// re-init
--- 454,467 ----
return false;
! _pwm_channel[channum].pin_out = pinout;
Zero_Timer bug.
- adafruit_support_mike
Re: Zero_Timer bug.
I'll have the folks who handle that library check it out. Thanks!
To help them along, what problem does the existing code cause, and how does the patch above fix it?
- smp
Re: Zero_Timer bug.
I haven't even gotten it to work yet, but if you read the code in that routine from top to bottom its obvious.
