Rotation of 5” TFT screen (PID 1596) driven by a RA8875
bsengrx2
Post by bsengrx2 »
I have been working with Arduino hardware for a couple of years and the complexity of my projects led me to need further resources and switched to Pi. I have a 3 b using both spi bus’ to read three MAX31855s and drive a 5” TFT screen (PID 1596) through a RA8875. Reading the Tcs and writing data to a file on the SD works fine, and the display can view the output of ra8875_simpletest.py. The only issue I had was finding the syntax to utilize the screen on the second spi bus:
spi = busio.SPI(clock=board.SCK_1, MOSI=board.MOSI_1, MISO=board.MISO_1)
display = ra8875.RA8875(spi, cs=cs_pin, rst=rst_pin, baudrate=BAUDRATE, width=800, height=480)
display.init()
For the application at hand, the tft screen needs to be in potrait mode. To achieve this I made the changes to /boot/config.txt recommended online in a variety of ways (display_rotate, LCD_rotate, 1, 90, ...). I feel the problem here lies in somehow not defining which screen the rotation is to apply to, similar to defining which hardware is on which spi bus.
Rather than dedicate a display to the Pi, I have been remoting in using SSH or RealVNC. When display_rotate=1 is added to boot/config.txt it results in rotation of the screen displayed through RealVNC but does nothing to the tft display output from ra8875_simpletest.py.
There are several lines in config.txt below I do not understand but think is where the problem lies.
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
enable_uart=1
start_x=1
gpu_mem=128
dtoverlay=spi1-1cs, cs0_pin=11
display_rotate=1
i did not post my code, fault messages, or error codes, as there is not a fault to report beyond the fact that the TFT screen does not rotate. This is my first post to this forum, I can provide further information as requested, and thanks in advance.
Tom
adafruit_support_mike
Re: Rotation of 5” TFT screen (PID 1596) driven by a RA8875
Are you using the RA8875 display as a framebuffer device (a display driven by the kernel) or are you controlling it from userland code?
bsengrx2
Post by bsengrx2 »
Userland code is my answer based on the fact that I do not have /dev/fb1 for the tft only /dev/fb0. Is this the correct reasoning for my answer or is there logs or some command output to use to confirm this. I followed the installation instructions here: https://learn.adafruit.com/ra8875-touch ... d/overview. Would this mean that userland code should address the orientation in the Python script and a framebuffer would be addressed in /boot/config.txt? If so I have not been able to find syntax that is accepted in the display definition such as:
display = ra8875.RA8875(spi, cs=cs_pin, rst=rst_pin, baudrate=BAUDRATE)
Is there a reason for a kernel solution rather than userland code? Does using a framebuffer mean it is permanent and the userland code needs xinput?
Thanks again
bsengrx2 wrote:Would this mean that userland code should address the orientation in the Python script
Yes. I'm pretty sure the options in /boot/config.txt only apply to displays managed by the kernel.
Fortunately, rotation is easy to do in code:
WIDTH = 800
HEIGHT = 480
def rotateCW (x, y):
	return( HEIGHT-y, x )
def rotateCCW (x, y):
	return( y, WIDTH-x )
bsengrx2
Post by bsengrx2 »
I was not clear in my problem statement. I need to display text in portrait mode or rotated 90 degrees. I can handle the changes from landscape to portrait relative to the (x,y) positions. Can the rotation of text be handled in userland code?
Hmm.. our Arduino GFX library has rotation, but it looks like the CircuitPython version doesn't.
The CircuitPython GFX library does use a function named pixel() that works as a connector between the generic graphics functions and the device-specific libraries. You can insert the rotation code above in the RA8875 library's pixel() function and it will rotate everything:
https://github.com/adafruit/Adafruit_Ci ... #L539-L548
