Just an update that I found the official power bank charger and now the low voltage warning is gone.
However still can't get the interactive display to show when installing. Done the recommended working version and the latest version, including OS lite. Also tried the console one as well.
Any ideas???
Will another installer script work or does it have to be on that one?
Need help installing Adafruit 2.4" PiTFT HAT with Resistive
- MarkIpswich
- MarkIpswich
Re: Need help installing Adafruit 2.4" PiTFT HAT with Resist
I've tried some old images, still don't work.
On this page however
https://learn.adafruit.com/adafruit-2-4 ... sy-install
The unsupported images:
PiTFT 2.4"/2.8"/3.2" Resistive Images
Raspbian Jessie 2016/9/23-based image
Raspbian Jessie Lite 2016/9/23-based image
Raspbian Jessie 2016/03/25-based image
Raspbian Jessie Lite 2016/03/25-based image
Raspbian Jessie 2015/09/24-based image
Raspbian Wheezy 2015/09/09-based image
Raspbian 2014/06/20-based image
Raspbian 2014/09/09-based image
I tried the top one to see if it would actually work which it did not. Come up with a couple of error messages.
But when doing the install script, the screen was still lit up but the white disappeared. It never done that before.
Does everything seem OK on the back of the sceen?
upload pic
Maybe the DPI connector? I presume that's the orange thing?
How do I see if that's properly connected?
Just to the left of that white thing, you can just about tell that white thing is not in a straight line.
In this image, it's fully straight
https://cdn-learn.adafruit.com/assets/a ... 1430340172
Any way in the terminal (with commands) I can see if it's working?
In the config file:
# --- added by adafruit-pitft-helper Sun Jun 27 08:23:59 2021 ---
hdmi_force_hotplug=0
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=pitft28-resistive,rotate=90,speed=64000000,fps=30
# --- end adafruit-pitft-helper Sun Jun 27 08:23:59 2021 ---
upload pic
In the config file:
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
- MarkIpswich
I do still think it could be the USB cable as when I plugged the cable into the mains (not power bank) the screen lit up, went a bit dark but it was flicking for a few seconds before stopping.
Can you please tell me the meaning of that?
That red light next to the green does go on and off also, BUT it does not do it with it plugged into the power bank.
The low voltage warning came back however.
Would this have enough power? With a Micro USB adapter of course.
https://www.amazon.co.uk/Anker-Thunderb ... B08D9J8HM3
Anker Thunderbolt 3.0 Cable 2.3 ft, Supports 100W Charging / 40Gbps Data Transfer USB C to USB C Cable, Ideal for Type-C MacBooks, Dell, iPad Air 4, iPad Pro 2020, Pixel, Hub, Docking, and More
It seems it does go over 3.3a but not sure.
- MarkIpswich
Oh and also from that code, with the cable plugged in without the low voltage warning:
pi@raspberrypi:~ $ vcgencmd measure_volts core
volt=1.3438V
pi@raspberrypi:~ $ vcgencmd measure_volts sdram_i
volt=1.2000V
pi@raspberrypi:~ $ vcgencmd measure_volts sdram_p
volt=1.2250V
pi@raspberrypi:~ $ vcgencmd measure_volts sdram_c
volt=1.2000V
pi@raspberrypi:~ $
volt=1.3438V
volt=1.2000V
volt=1.2250V
volt=1.2000V
pi@raspberrypi:~ $
- mikeysklar
Which model of Pi did you say you are using? I was not able to locate that in the message history, but that will help with cable selection. The USB-C cable you asked abou the specs being enough looks good for a Pi 4.
The ribbon connector is indeed suspect (I think it is a 40-pin FPC). You can pull the black tabs and re-insert it then lock the tabs back into place. As you suggested it should be straight / aligned and not angled like that.
- MarkIpswich
It's the PI 3B+
I do have a Zero W, I could use it on there but I prefer it to be on the other.
I'll do the adjustments on that tomorrow for the board.
- MarkIpswich
Guess what? It works!
I just got it connected to the soldered pins!
I may need some more help though.
- MarkIpswich
The desktop is displayed and I am unable to do anything by touch. I presume I need a raspberry pi stylus pen?
It's the touch screen one I got.
I do have a stylus but it's not a PI one, would a non PI one work?
- mikeysklar
Good job getting the display going. It sounds like it was the misaligned 40-pin FPC ribbon connector?
The touch part is more difficult to get going if it did not come up automatically. I think the newer device tree layout hides some of the /dev files we have come to depend on. Try a few of the suggested tools here and let me know if you find some devices missing.
https://learn.adafruit.com/adafruit-2-4 ... -calibrate
- MarkIpswich
No it was them headers. Didn't want to know for some reason.
Do I need to do all of that guide for the touchscreen to fully work? I only want it so I can use it via a pen / hand touch
- MarkIpswich
I can actually use the touchscreen so got no problems with that.
How do I rotate the screen so it's 270 degrees?
- mikeysklar
What was the solution for getting the touchscreen going?
screen rotation is done through the /boot/config.txt which already has a rotate=90 in it.
- MarkIpswich
I didn't do anything. I tried today with a finger and it worked. Tried yesterday but didn't do anything. Obviously I didn't try hard enough.
Thanks, I'll do that.
- MarkIpswich
When using a pen with it (not the official one) if I use it in the bottom right then the mouse thing is picking it up to the top left.
Such as I open the menu from the bottom right using the pen instead of doing if top left.
I have done the screen so it's the correct way. 270 degrees in the config file.
- mikeysklar
You will need to go through the manual calibration setup.
https://learn.adafruit.com/adafruit-2-4 ... 2859019-17
If the "automagic" calibration technique isn't working for you, or you have some other setup where you need to carefully calibrate you can do it 'manually'
You will want to calibrate the screen once but shouldn't have to do it more than that. We'll begin by calibrating on the command line by running
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
follow the directions on the screen, touching each point. Using a stylus is suggested so you get a precise touch. Don't use something metal, plastic only!
You should see five crosshair targets. If you see less than that, the touchscreen probably generated multiple signals for a single touch, and you should try calibrating again.
Next you can run
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_test
which will let you draw-test the touch screen. Go back and re-calibrate if you feel the screen isn't precise enough!
