Monitoring AC Current
Re: Monitoring AC Current
by jcarroll on Sun Nov 21, 2010 11:00 pm
The shunt resistor in the circuit shown is tie impedance between two A/D ports. Probably many K ohm.
jcarroll
by zener on Mon Nov 22, 2010 1:01 am
jcarroll wrote:The shunt resistor in the circuit shown is tie impedance between two A/D ports. Probably many K ohm.
I think you are incorrect on that. R1 is clearly associated with the CT and is typically specified in the range of < 500 ohm. However, I will let others have their opinion, if any.
zener
by richms on Mon Nov 22, 2010 1:17 am
I thought that CT's tended to have something in them to limit the voltage to "safe" levels depending on the class of wiring they had on the output - a MOV or similar.
richms
