Cross-talk when using ADS1115 with a mux
alexdry
Post by alexdry »
I'm trying to read several pots with 16-bit resolution using an ADS1115 and a CD4051 mux with a Teensy LC. It works fine except from when I twist a pot close to its maximum value. When a pot starts rising above approximately 58,000 in the serial values I read, there is a horrible cross-talk and the other pots rise in values too. For example if pot 1 goes above 58,000 and pot 2 is at 12,000, when pot 1 reaches its maximum limit, pot 2 will have gone up to 28,000.
Here's the circuit:
And here's the code (the code is written for a 16 channel mux, since it's for a project that should support those, it shouldn't matter here though):
#include <Wire.h>
#include <Adafruit_ADS1X15.h>
#define POTDELAY 50
Adafruit_ADS1115 ads;
const int numMuxCtlPins = 4;
const int numPots = 2;
unsigned int pots[numPots];
int muxCtlPins[numMuxCtlPins] = {2, 3, 4, 7};
int muxCtlValues[numMuxCtlPins] = { 1, 3, 7, 15 };
void readPots() {
  int16_t results;
  Serial.print("pots");
  for (int pot = 0; pot < numPots; pot++) {
    for(int pin = 0; pin < numMuxCtlPins; pin++) {
      digitalWrite(muxCtlPins[pin], (pot & muxCtlValues[pin]) >> pin);
    delayMicroseconds(POTDELAY);
    results = ads.readADC_Differential_0_1();
    // add 32768 to offset the value to start from 0
    uint32_t uResults = results + 0x8000;
    pots[pot] = uResults;
    Serial.print(" ");
    Serial.print(responsivePots[pot]);
  Serial.println();
void setup(void)
  for (int i = 0; i < 4; i++) {
    pinMode(muxCtlPins[i], OUTPUT);
    digitalWrite(muxCtlPins[i], LOW);
  // 2x gain   +/- 2.048V  1 bit = 1mV      0.0625mV
  ads.setGain(GAIN_TWO);
  ads.begin();
  Serial.begin(115200);
  while (!Serial);
void loop(void)
  readPots();
Any help is greatly appreciated.
adafruit_support_mike
Re: Cross-talk when using ADS1115 with a mux
It looks like you're using 4.096V as your reference voltage for the ADC. Is your VCC 5V or 3.3V?
alexdry
Post by alexdry »
adafruit_support_mike wrote:It looks like you're using 4.096V as your reference voltage for the ADC. Is your VCC 5V or 3.3V?
My VCC is 5V. The voltage reference should be correct.
Thinking twice, the 4051 mux is powered with 3.3V and not 5V as shown in the circuit image. Could that be an issue? I am currently away from the circuit so unfortunately i can't check right now. Still, when I twist one potentiometer, its readings seem correct, excluding the cross-talk.
Powering the 4051 with a voltage lower than the voltage across the potentiometers would cause problems, yes. Make sure the 4051 has 5V and see if that has any effect on the crosstalk.
alexdry
Post by alexdry »
Powering the mux with 5V solved the issue. There is a bit a cross-talk now, but nothing compared to the initial problem. Still I think it's better to use one ADS1115 for every two pots and mux the ADS1115 with an I2C mux, there should be no cross-talk. Thanks for the help.
You could also look at other analog switches. The 4051 is an old standby, but its nominal channel resistance is about 500 Ohms.
The TS3A44159 is a quad 2-SPDT mux with a nominal channel resistance of about 0.5 Ohms, and a worst-case resistance of a couple Ohms:
https://www.ti.com/lit/ds/symlink/ts3a4 ... 6570884423
