Hello!
I plan to make the DIY Darksaber (https://learn.adafruit.com/ble-darksaber-propmaker). One question I had was what type of 3D printer filament was used for the blade? It looks like a white translucent filament (PLA). Can you provide an example? For example, can I use any of the below from amazon?
SUNLU Clear PLA Filament 1.75mm, 3D Printer Filament Transparent PLA Dimensional Accuracy /- 0.02 mm, 1KG
https://www.amazon.com/gp/product/B07ZN ... LPGH&psc=1
SUNLU PLA 3D Printer Filament, PLA Filament 1.75 mm Dimensional Accuracy +/- 0.02 mm, 1 KG Spool, PLA White
https://www.amazon.com/SUNLU-Printer-Fi ... ial&sr=1-1
Or please recommend a filament? Also, it may be helpful to post this or at least a suggestion within the DIY Howto.
Thank you!
Cheers,
Skkaw
Dark Saber "white" 3D printer filament
- mikeysklar
Re: Dark Saber "white" 3D printer filament
@Skkaw,
The dark saber blade uses a clear PLA. The spools you have located on Amazon look right for this application.
Be sure to use slice settings close to the recommended ones in the guide:
PLA filament 220c extruder
0.2 layer height
10% gyroid infill
60mm/s print speed
60c heated bed
- Skkaw
mikeysklar thank you! This is great. Appreciate the reply.
-Skkaw
-Skkaw
