Rotary Encoder Help ?
BillPretty
Post by BillPretty »
Does anyone have experience with rotary (quadrature) encoders ?
I appear to get two events for every click of rotation.
I am using python to debounce the switch:
from gpiozero import Button
import time
input_A = Button( 18, bounce_time = .1)
input_B = Button( 23, bounce_time = .1)
old_a = True
old_b = True
def get_encoder_turn():
    # return -1, 0, or +1
    global old_a, old_b
    result = 0
    new_a = input_A.is_pressed
    new_b = input_B.is_pressed
    if new_a != old_a or new_b != old_b :
        if old_a == 0 and new_a == 1 :
            result = (old_b * 2 - 1)
        elif old_b == 0 and new_b == 1 :
            result = -(old_a * 2 - 1)
    old_a, old_b = new_a, new_b
    time.sleep(0.001)
    return result
x = 0
while True:
    change = get_encoder_turn()
    if change != 0 :
        x = x + change
        print(x)
adafruit_support_mike
Re: Rotary Encoder Help ?
Both signals on the encoder change with each click, they just do it at different times. The code above will respond to both changes.
It looks like your code is similar to the running-sum decoding method, but can be simpler: just return 1 when channel A changes, -1 when channel B changes, and 0 if there's no change.
Then your variable 'x' in the while() loop will alternate between 0 and 1 when A changes first, and between -1 and 0 when B changes first.
Add a conditional to print the value of 'x' when it isn't 0, and you'll get one value that indicates direction per click.
BillPretty
Thanks for the help. The code is from a book I am reading, so I will try your method.
BillPretty
I tried to implement your idea without success.
While trouble shooting with a DVM (all I have) I noticed that the output of terminal A and B is a pulse
rather than a steady state. I think my function needs more tests, but I'm not sure how to do this.
    global old_a, old_b
    result = 0
    if new_a != old_a :
            result = 1
    if new_b != old_b :
	if old_b == 0 and new_b == 1:
	    result = 1
    time.sleep(0.01)
    return result
The switch values don't matter.. only whether they've changed since the last time you read them:
prev_a = 0
prev_b = 0
def check( a, b ):
	global prev_a, prev_b
	if ( a != prev_a ):
		prev_a = a
		return( 1 )
	if ( b != prev_b ):
		prev_b = b
		return( -1 )
	return( 0 )
count = 0
def direction( inc ):
	global count
	count += inc
	if (( inc != 0 ) and ( count != 0 )):
		print( count )
in_a = [ 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0, 0, 0 ]
in_b = [ 0, 0, 0, 1, 1, 1, 1, 0, 0, 0, 0, 1, 1, 1, 1, 0 ]
for n in range( 0,16 ):
	direction( check( in_a[ n ], in_b[ n ] ) )
	direction( check( in_a[ 15-n ], in_b[ 15-n ] ) )
The code above iterates the same set of switch values in opposite directions. Going forward produces 1, going backward produces -1.
The sequences have duplicate values to approximate reading the switches and seeing no change. The loops only produce output when a switch value changes, and the 'count' value is nonzero.
BillPretty
Thanks to Google, I found a Python module called "Encoder" which I used to implement the following code:
import Encoder
enc = Encoder.Encoder(18,23)
while True:
	x = enc.read()
	print (x)
I get the same results as with my other code (multiple events per click).
I believe I have a hardware problem so I intend to build the circuit shown below;
EncoderCircuit 2.jpg (26.92 KiB) Viewed 204 times
BillPretty
I have found that the following code works with the schematic shown above.
I used a 0.1uF capacitor and the circuit works reliably.
The 74HC14 works with a Vcc from 2 - 6 volts, so the circuit can also be used with the Arduino Uno.
The software uses a PWM (pin 10) of the Arduino to control the brightness of an LED.
The LED is connected to ground through a 270 ohm resistor.
# This code works with the Schmitt trigger circuit
# It also talks to an Arduino Uno to control the
# brightness of an LED using a PWM pin (10) of the Arduino
import pyfirmata
import time
board = pyfirmata.Arduino('/dev/ttyACM0')
led_pin = board.get_pin(' d:10:p')
input_A = Button(18)
input_B = Button(23)
# Counter starts at 50 to avoid negative values
# Software needs a test for counter < 0 and > 100
counter=50
change = 0
LastState=input_A.is_pressed
while True:
	aState=input_A.is_pressed
	if aState > LastState:
		bState=input_B.is_pressed
		if bState != aState:
				counter = counter+1
		else:
			counter = counter -1
		change = 1
	if aState !=0 and change==1:
		print (counter)
		led_pin.write( counter / 100.0)
	LastState = aState
	change = 0
Glad to hear you got things working. Happy hacking!
