BME 280 - does the new STEMMA QT model work identically to t
beacon1996
Post by beacon1996 »
I've been using the pre-November 2020 BME 280s for some time. I need to order more and see that the design has changed. Can someone confirm that the new STEMMA QT model is interchangeable with the old model (with just the addition of the STEMMA QT connection?).Thx.
adafruit_support_carter
Re: BME 280 - does the new STEMMA QT model work identically
Yep, should be interchangeable. The update to the STEMMA connector is really just a convenience thing. And you don't have to use the STEMMA QT connector if you don't want to. The row of header pins should behave the same as the old version.
