adafruit PN532 RFID/NFC Shield
officialPiUser
Post by officialPiUser »
I recently bought the adafruit PN532 RFID/NFC Shield.
When I plug it in the power led does not light up.
The test programm from the adafruit tutorial doesen't work as well.
It says that no SPI connection is found.
I also measured with a multimeter that the 3,3V are connected right, but the board didn’t respond.
What can I do?
adafruit_support_mike
Re: adafruit PN532 RFID/NFC Shield
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
officialPiUser
On the other side I have connected the NFC Reader with a Raspberry Pi 3B+ via Jumper Wire.
Pi 3V to3.3V
Pi GND to GND
Pi MOSI to MOSI
Pi MISO to MISO
Pi SCLK to SCK
Pi D5 to SS
As a sanity check, what voltage do you see between the 3.3V and GND pins parallel to the ones with the wire connections?
officialPiUser
Measuring with the multimeter I see the 3.3V at the free conection points.
Okay, that confirms basic power in the wiring.
Try connecting power to the 5V pin instead of the 3.3V pin. See if that makes the power LED light.
officialPiUser
It worked.
The power LED turned on.
aahmed1
Post by aahmed1 »
officialPiUser wrote:It worked.
I am having the same connections you have and I got the shield to be powered on but the device is not recognized on my PI
is it working with you ?
That was my next question:
@officialPiUser: now that the PN532 breakout's power is good, can you control it from the RasPi?
officialPiUser
Yes.
I can controll it with the Pi and it recognizes the NFC Tags.
Glad to hear you got it working. Happy hacking!
aahmed1
Post by aahmed1 »
officialPiUser wrote:Yes.
I have been trying to get it to work for a while now
I have the same connection you have
Pi 5 v to 5v
Pi Gnd to Gnd
Pi MOSI to MOSI
Pi MISO to MISO
PI SCLK to SCK
PI D5 to SS
and SEL0 and SEL1 are both closed or soldered
but I have the busy led always on I do not know why and the PN532 is not detected.
Post a photo showing your hardware and connections and we’ll take a look. 800x600 images usually work best.
