I have purchased a PCA9685 16-Channel Servo Driver and have not been able to get it to work, when I run the Servo example the servo motors do nothing. Tested with 2 versions of Arduino Uno, using 2 different computers with different operating systems (MacOS & Ubuntu).
In the video of the following link I show the connections of the pins, the power supply (PC power supply), the voltage measurement, everything. I have checked everything numerous times and wonder if I am doing something wrong or if the module is faulty.
https://youtu.be/nUXy_nl48oE
Note: the video is not "searchable" on YouTube, it is possible to access it only if the link is known, I have posted it only so that the pin connections can be seen, etc., and I will remove it when I have confirmed if I am doing something wrong or if the module is faulty.
Problem with PCA9685 16-Channel Servo Driver
- roilldcuba
Re: Problem with PCA9685 16-Channel Servo Driver
That does not appear to be an Adafruit board. The seller or manufacturer should be able to help you with technical issues.
- roilldcuba
Thank you. So the problem is the board, not the connections made by me?
I don't see any obvious issues with the wiring.
- roilldcuba
Ok, thank you for the time you have dedicated to me
