I use a VCNL4010 on an Arduino One board. If I connect it with short cables everything works fine.
But I need the IC on a distant of 3 metres. If I connect it with (4) longer cables it tells me: Sensor not found.
All 4 cables are well connected. Is this a timing problem?
I checked the code in file VCNL4010.cpp and it looks like it gets a wrong REGISTER_PRODUCT.
This happens at line 32.
Can anyone help?
VCNL4010: Sensor not found
- dastels
Re: VCNL4010: Sensor not found
Yes, I2C is meant for short distances, originally between chips on the same board. It doesn't do as well with long distances.
Have a look at https://www.adafruit.com/product/4756 for a way to get around that. That should be enough for 3m. For longer cables you should use twisted pair to reduce RF noise. The guide at https://learn.adafruit.com/adafruit-ltc ... terminator discusses that.
- GerlachvB
Thanks. I didn't know that. This answer really helps.
