Hi Folks,
I bought 3 MAX31865 temperature sensor amplifiers for the RTD - PT100 temperature sensor.
Just because I was feeling paranoid, I checked the resistor on the board, and it reads 4301, which should be used for the PT1000 sensor, not the PT100 sensor.
Am I reading this correctly?
Picture of the resistor attached.
Thanks in advance, Peter
MAX31865 - is this PT100 or PT1000?
Re: MAX31865 - is this PT100 or PT1000?
There are 2 different marking systems for SMT resistors - 3 digits and 4 digits. They are similar enough to be confusing.
The resistor on your board uses a 3-digit code. The first two digits are the significant digits, the third is the multiplier (i.e. how many zeros to add)
So "431" is 430 Ω which is correct for a PT100.
https://learn.adafruit.com/adafruit-max ... aq-3012913
If marking is 4300 or 431 its PT100
If marking is 4301 or 432 its PT1000
- pthompson509
Thank you. As always, it helps to read ALL of the descriptive text, doesn't it?
Cheers!
Cheers!
