USB to TTL Serial Replacement Parts
alienbike
Post by alienbike »
We have dozens of the Adafruit USB to TTL serial adapters with the Dupont connector. The issue is that after years of use, we are starting to see some broken wires. We need a source for the crimp pins so that we can repair these. I would prefer not to replace the whole connector if the problem is only a single broken wire.
mikeysklar
Re: USB to TTL Serial Replacement Parts
Post by mikeysklar »
@alienbike,
Which product? id# or link please.
alienbike
Post by alienbike »
The product id is 70. I found a Digi-Key part A25983-ND the works.
mikeysklar
@alienbike,
That you for including the digikey part# for the crimp pin. I think this will be helpful to others.
Did you also use a special crimp tool or just pinch down with plyers?
alienbike
Post by alienbike »
I use a generic crimper. It has five different dies for various crimps. Purchased on Amazon as Engineer PA-09.
mikeysklar
@alienbike,
Perfect, thank you for the deets.
Sounds a lot like ours:
https://www.adafruit.com/?q=universal+p ... =BestMatch
