https://www.adafruit.com/product/4218
I purchased this to cut the male end off and reuse in another project but it doesn't seem to use a standard wiring layout. Before I sacrifice another USB C cable to test it I thought I'd ask here if anyone happens to know?
Anyone know the color/pin codes for this?
- fliberdygibits
- mikeysklar
Re: Anyone know the color/pin codes for this?
No color codes, but I wanted to make sure you had seen the datasheet for this.
https://cdn-shop.adafruit.com/product-f ... __30CM.pdf
- fliberdygibits
I saw this but it doesn't really help me identify what I need. Inside this cable are some pairs that are bundled together separate from the other wires which Is what I thought the "8"s where indicating but there are only 4 of those bundles and not 5 and I tried some testing but am not having any luck. I've searched online for USB codes and most of what I find doesn't correspond to the way these cables are bundled or numbered or colored. I COULD sacrafice another USB C cable to have a way to test but I don't have any cables I want to cut up so I'll have to buy another cable.
