Here is the script, which needs critiqued...
#importing the necessary modules
from datetime import datetime
from gpiozero import Button, LED
from picamera import PiCamera
from time import sleep
from signal import pause
imagebutton = Button(23)
red = LED(17)
previewbutton = Button(24)
white = LED(27)
videobutton = Button(25)
blue = LED(22)
camera = PiCamera()
running = True
camera.resolution = (1024, 768)#use this to set the resolution
white.source = previewbutton.values
red.source = imagebutton.values
blue.source = videobutton.values
previewbutton.when_pressed = camera.start_preview
previewbutton.when_released = camera.stop_preview
timestamp = datetime.now()
def picture():
camera.capture('pic'+str(timestamp)+'.jpg')
sleep(2) #give the camera two seconds
imagebutton.when_pressed = picture #execute the picture function
def video():
camera.start_recording('vid'+str(timestamp)+'.h264')
camera.wait_recording(15)
camera.stop_recording
sleep(2)
videobutton.when_pressed = video #execute the video function
try:
while running:
print('Active') #displaying 'Active' to the shell
sleep(1)
#we detect Ctrl+C then quit the program
except KeyboardInterrupt:
camera.stop_preview()
running = False
pause()#keep the script alive
Some questions:
1. Should there have been resistors between the GPIO pins and components? Specifically, a pull down resistor for the arcade buttons?
The code recognizes that the button is pushed when the pin goes high. This means the button will be pulled low and only go high when the button is pressed.
2. Should I have resistors on the negative(cathode) side of the led sequins?
3. The power switch - When the RPI zero is off the led still glows?
As always thank you very much for advice, tips and any help provided.
Sincerely,
Mr. Beginner 1.0 :)
