problem moving from 19 to 21
by jcarroll on Sat Nov 20, 2010 7:30 pm
I have a sketch that compiles and runs beautifully from the 19 installation but hangs when compiled installed from the 21 system.
Windows, Duemilanova and UNO boards. An Adafruit log shield is involved
The includes:
#include <SdFat.h>
#include <SdFatUtil.h>
#include <Wire.h>
#include <RTClib.h>
#include <EEPROM.h>
Then:
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
The program compiles and loads fine and hangs somewhere in this:
PgmPrintln("Program Starting");
if (!card.init(SPI_HALF_SPEED)) error("card.init failed");
Serial.print("card initialized \n");
hilo( 1 , beepPin, 750); // celebrate a good start
if (!volume.init(&card)) error("volume.init failed");
Serial.print("volume initialized \n");
if (!root.openRoot(&volume)) error("openRoot failed");
Serial.print("Root directory opened \n");
At this point there has been no activity in any of the buffers. EEPROM is used after a few more lines of code.
This all compiles to 20 K of code. When run from 19 the program reports 60 bytes of remaining RAM.
Can someone see that I have missed something important and obvious about migrating from one version to the other?
It would be inviting to keep using 19 and not solve the problem, but the new boards are UNOs.
Thanks in advance.
John C
jcarroll
Re: problem moving from 19 to 21
by franklin97355 on Sat Nov 20, 2010 8:06 pm
When it compiles in 21 how much ram is remaining? If you included the code others could try it out.
franklin97355
by jcarroll on Sat Nov 20, 2010 8:43 pm
Now that I check, if this is included, it hangs on:
Serial.print("Remaing Ram = ");
Serial.println(FreeRam());
right after the =
I will try the FreeRam function in some sample code.
The code will hang right away if the properly configured and wired shield is not attached.
JC
jcarroll
by jcarroll on Sat Nov 20, 2010 8:49 pm
The freeram function works fine when stuck into some example code.
It seems like I came across a reference to a change that needs to be made in EEPROM or wire but I cannot find it again.
jcarroll
