Post Breadboard connecting
by Breyyne on Mon Nov 22, 2010 11:33 am
I am past the prototyping phase of a project. What would be the best way to make a more semi permanent connections between the Arduino and non shield components? For example like making a pass-thru cable for the 16x2 LCD screen and the Arduino. I am thinking something like the 6-conductor 0.1" socket-socket cable ( http://www.adafruit.com/index.php?main_ ... cts_id=206 ) But with a male pins on one side or even a kit to make them yourself.
Breyyne
Re: Post Breadboard connecting
by franklin97355 on Mon Nov 22, 2010 12:36 pm
The components are called "IDC" (insulation displacement connector) and you can get them in many different configurations. I use a pana-vice to crimp them on but have not had a need for them recently so I don't have any supplier info.
franklin97355
by adafruit_support_bill on Mon Nov 22, 2010 12:49 pm
The Adafruit Proto-Shields are extremely handy for that sort of thing. In addition to all your breadboarded components, you can solder pin-headers for common connectors: Use 1 row for cables like the 6-conductor cable in your link. Or use 2 rows for the usual IDC connectors and ribbon-cable.
by chankster on Mon Nov 22, 2010 12:57 pm
Check out Molex Catalog 'C'. It should have what you're looking for.
http://www.molex.com/catalog/web_catalog/pdfs/C.pdf
"This is not my sig", it said. - I looked at it suspiciously; Who's sig was it, then?
chankster
by Breyyne on Tue Nov 23, 2010 9:07 am
Thank you Franklin and Chank. Exactly what I was thinking of. I am a bit of a neat freak when it comes to my wiring and until just recently the smallest components I would deal with were computer parts. So I am used to those type of connections. In fact I have a parts box full of the larger IDC's for in computer power distro.
Breyyne
by stinkbutt on Tue Nov 23, 2010 12:27 pm
If you want a permanent board, you could upgrade from breadboard to protoboard, though if you're a neat freak I'm sure you realize the board'll end up looking like it got puked on by a soldering gun. The other option is learning Eagle and banging out a professional looking board, which may be overkill.
It's all a matter of how much you want to learn that process, and how badly your OCD compels you to make a clean project, I guess.
Red M&M, Blue M&M: They all wind up the same color
stinkbutt
